Welcome to the RAS Solution Forums HEC-RAS Help Terrain does not fit to geometry layers
  • #6112
    Hello, I would like to ask you for help. I have a problem wih exporting GIS2RAS file. I am using HECGeoRAS 10.2 and HEC RAS 5.0. After I import GIS2RAS file to HEC RAS it does not fit with the terrain layer, I can view it but it is far from each other. I checked a projection but it seems to be the same, I tried to export it many times, just once it was
    ok (bud unfortunately the wrong version of geometry) that´s why I think there is problem with a geometry not terrain file. I think I always did the same and it worked once but didn´t work afterwards….Do you have any idea?
    #9942
    If I open a source code, there are different coordinates (comparing wrong and right file) and different viewing rectangle….Is there any possibility in HECgeoRAS or ArcMap how to fix it? (I don´t have an ArcMap file with the right geometry projection)
