Welcome to the RAS Solution Forums HEC-RAS Help Terrain Association
Viewing 11 posts - 1 through 11 (of 11 total)
  • #18106
    Bill Buckley
    I am creating a very simple 2D project and continue to get “Cannot recompute 2D property tables – no terrain associated with this geometry”.
    The terrain and projection are set and match with imagery
    The geometry file was created first in the geometry editor before being created in RAS-MAPPER
    The geometry is associated with the terrain.
    I’ve tried different terrain data sets and projections with the same results.
    I have closed and reopened HEC-RAS. I have closed and reopened by computer. I have tried it on different computers.
    I have completely rebuilt the project in a new file.
    I’m thinking that there is a setting in my model that is not letting the geometry and terrain associate within the plan.
    Any thoughts?
    #18107
    Luis Partida
    I bet you have a red cell error that is not being shown in RAS Mapper. I still refuse to build out geometries in RAS Mapper as it is still buggy. Open the geometry data editor with RAS Mapper closed, then check the bottom left for a red message saying there is a cell with more than 8 sides and either fix it with a breakline or manual edit.
    The other option I would suggest is to rebuild it again in a fresh environment and do not use RAS Mapper for anything
    #18111
    Eric R
    Bill, Have you tried creating this geometry first in RAS Mapper and then populating it in the geometry editor?
    #18114
    Bill Buckley
    Thank you Luis and Eric. There was no error message for a cell with more than 8 sides. I’ve tried both suggestions in completely new builds
    and still getting the same error message. Very disheartening.
    #18115
    Eric R
    What is the average cell size of your model?
    #18116
    Bill Buckley
    #18117
    Eric R
    Do you mean that each cell in your model has an average dimension of 10397 ft?
    • This reply was modified 2 years, 3 months ago by Eric R.
    #18119
    Bill Buckley
    Cell sizes are 100′ x 100′ but average out to that amount when considering the cells on the edges
    #18120
    Bill Buckley
    I’ve tried a smaller cell size 50’x50′ which is 3563 cells and avg 2553 sf, but same error message
    #18122
    Eric R
    Try a newer or older version of HR.
    #18123
    Bill Buckley
    Thank you Eric and Luis for your help. I figured it out. I always create a Projection folder, Terrain folder, and Plan folder at the start of a project. So far so good, but when I created my terrain I didn’t use the default directory, but sent it into the Terrain folder I created, so the geometry was looking in the wrong location for the terrain and that is why I kept getting that error message. Hopefully this helps anyone else who made this mistake.
    Thanks again.
