Welcome to the RAS Solution Forums HEC-RAS Help Terms and Conditions
  • #6991
    Is anyone aware of a way to automatically suppress the Terms and Conditions message within HEC-RAS? I need to run several hundred simulations on an array of virtual machines via a script and would like to avoid this message. Once each virtual machine gets queued up via a job controller the computer will see it as the first time software is being used on that machine and it holds up the process until it is manually acknowledged.
    Thanks in advance for any tips.
    #11591
    No i dont.
    But i want to work w you and where you work
    #11592
    Don’t think there is a need to turn of the terms and conditions at start up. We set up an image with HEC-RAS installed and security updates turned off. We then spin up thousands of machines and have it run HEC-RAS in the background using python.
    #11593
    Yea i wanna work there too lol
