Welcome to the RAS Solution Forums HEC-RAS Help Tailwater connection for lateral stuctures
  • This topic has 4 replies, 111 voices, and was last updated 6 years ago by Zoran.
  • #7496
    Zoran
    Does anyone know how the lateral structure tailwater connection work?
    There are 2 columns in the “TW Lateral Structure Connections” editor :
    – column “Weir station” : Weir stations are reported along the edge of the 2d flow area that is adjacent to the lateral structure (0 corresponds to the projection of the beginning of the LS). Usually the first value is negative (as the first cell begins before the LS). The 2nd value indicates the ending of the first cell, the 3rd the ending of the 2nd cell, and so on. RAS is then able to know in which cell water overflowing a LS has to be injected.
    – column “2D Face Points” : As for as I understand it, this column should indicate the face of the cell where the water is redirected for the corresponding portion of LS (as defined in “weir station”).
    I think I am missing something, as in the example “Bald Eagle Multi 2D Area” for the LS 14800 the first 2 lines indicate:
    1829 -144.1203
    1793 151.5218
    When I do “Find face” on the corresponding 2D area and I indicate 1829 I don’t obtain the adjacent face.
    Here an illustration.
    I couldn’t find useful information in the RAS documentation.
    Does anyone has a valid explanation?
    HEC-RAS version 5.0.3
    Zoran
    #12567
    face points are not faces. Facepoints are the nodes where different faces connects. I know that users can be forced into using old versions for various reasons, but 503 was several versions ago.
    #12568
    Zoran
    So is there a way to know how the facepoints are numbered? There is the possibility to indicate “user defined weir stationing” but for that I imagine I should know which facepoints are limiting my LS.
    Thank you,
    Zoran
    PS: Usually I use version 507, but this time I had to do a test with version 503.
    #12569
    In RAS mapper, under geometry and then 2D areas you should be able to right click and turn face point numbers on.
    I don’t know if you can do it from the lateral weir editor.
    #12570
    Zoran
    Thank you Jarvus. Now it makes sense:
