Welcome to the RAS Solution Forums HEC-RAS Help Tabular output for internal 2D Area structure
  • #6327
    Does anyone know if there is a way to get tabular output from an internal 2D area structure? I am looking for additional hydraulic outputs other than what is available in RAS Mapper. When I try to get tabular output from the structure the option for SA/2D connections is grayed out and I cannot get any tabular results. I did not see anything in the computation options that looked like it would help.
    A couple things worth noting:
    The structure spans multiple cells
    I am using 2D equations for flow over the structure (I’m guessing this is why tabular output isn’t available)
    Any help would be greatly appreciated
    Thanks!
    #10336
    For an internal 2D structure, there isn’t any output under the “detailed output tables” like you would normally get with the post processor for a lateral structure.
    There is DSS output. If you go to the stage and flow hydrographs and select Storage connectors. Or you can left click directly on the structure in the geometry editor and select plot stage and flow.
    This should give flow output even if 2D equation is selected.
