Welcome to the RAS Solution Forums HEC-RAS Help System Runtime Interop Services Errors
  • #5577
    jwatermolen
    Please help. I am new to working with HEC-RAS and HEC-GEORAS and am providing GIS support to NRCS engineers. I have run into a problem import the GIS data from HEC-RAS to build the inundation map. The 2 different times I have run throught the process I get the following errors File -Error 2 is the first time I ran the import and set the terrain value to a TIN. When I set the terrain value to grid I get an error of Error in AddGrid to ArcMap
    Please let me know of anything that can be of help to solve this problem.
    Thank you
    John Watermolen
    #8914
    jadams
    Make sure the background processing is turned off. Under geoprocessing-Geoprocessing Options. Also I have found that if you are working on a server the program crashes often. You may want to try moving all your data locally on your machine and try it if the problem persists.
    #8915
    jwatermolen
    Thank you. As I work through this process, everything seems to go smoothly until I try to do the floodplain deliniation. Then I get the follow error that I am embedding in this post
    any ideas would be appreciated
    Thanks again in advanced
    John
    #8916
    jadams
    I just tried it with my data set and got the same error. I changed the output directory to a folder on my local machine (not on our server) and it worked fine.
    #8917
    jwatermolen
    Return-path:
    Envelope-to: [email protected]
    Delivery-date: Mon, 08 Sep 2014 07:26:55 -0700
    Received: from mail-bn1bon0079.outbound.protection.outlook.com ([157.56.111.79] helo=na01-bn1-obe.outbound.protection.outlook.com)
    by joe.nabble.com with esmtp (Exim 4.72)
    (envelope-from )
    id 1XQzuB-00043j-BU
    for [email protected]; Mon, 08 Sep 2014 07:26:55 -0700
    Received: from BY2PR06CA001.namprd06.prod.outlook.com (10.255.247.11) by
    BLUPR06MB164.namprd06.prod.outlook.com (10.242.190.23) with Microsoft SMTP
    Server (TLS) id 15.0.1024.12; Mon, 8 Sep 2014 14:26:27 +0000
    Received: from BN1BFFO11FD041.protection.gbl (2a01:111:f400:7c10::1:145) by
    BY2PR06CA001.outlook.office365.com (2a01:111:e400:2c16::11) with Microsoft
    SMTP Server (TLS) id 15.0.1024.12 via Frontend Transport; Mon, 8 Sep 2014
    14:26:26 +0000
    Received: from mail.usda.gov (199.135.140.13) by
    BN1BFFO11FD041.mail.protection.outlook.com (10.58.144.104) with Microsoft
    SMTP Server (TLS) id 15.0.1019.14 via Frontend Transport; Mon, 8 Sep 2014
    14:26:25 +0000
    Received: from 001FSN2MPN4-161.001f.mgd2.msft.net ([169.254.1.31]) by
    001FSN2MMR1-003.001f.mgd2.msft.net ([199.135.140.13]) with mapi id
    14.03.0195.002; Mon, 8 Sep 2014 14:25:36 +0000
    To: “jadams [via HEC-RAS Help]”
    Subject: RE: System Runtime Interop Services Errors
    Thread-Topic: System Runtime Interop Services Errors
    Thread-Index: AQHPyRw6m8xSyzvhuEyyNndOXGyhQZv3T0FQ
    Date: Mon, 8 Sep 2014 14:25:36 +0000
    Message-ID:
    <[email protected]>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    x-originating-ip: [199.158.127.220]
    boundary=”_000_CC7D70A42380404292EB449163C108D09E1DEA001FSN2MPN4161001_”
    MIME-Version: 1.0
    X-EOPAttributedMessage: 0
    X-Forefront-Antispam-Report:
    CIP:199.135.140.13;CTRY:US;IPV:NLI;EFV:NLI;SFV:NSPM;SFS:(10009017)(438002)(377454003)(189002)(199003)(92566001)(19617315012)(92726001)(87936001)(90102001)(54356999)(79102001)(76176999)(19300405004)(512954002)(77982001)(14971765001)(15975445006)(71186001)(21056001)(95666004)(85306004)(22756005)(22746005)(86362001)(2656002)(77096002)(106116001)(104016003)(83072002)(85852003)(84676001)(106466001)(86146001)(81156004)(85806002)(19625215002)(84326002)(16236675004)(81542001)(33656002)(20776003)(4396001)(97736003)(76482001)(81342001)(110136001)(15202345003)(50986999)(66066001)(74662001)(74502001)(69596002)(68736004)(19580405001)(83322001)(55846006)(19580395003)(107886001)(80022001)(31966008)(6806004)(107046002)(44976005)(46102001)(99396002)(79686002);DIR:OUT;SFP:1101;SCL:1;SRVR:BLUPR06MB164;H:mail.usda.gov;FPR:;MLV:sfv;PTR:InfoDomainNonexistent;MX:1;A:0;LANG:en;
    X-Microsoft-Antispam: BCL:0;PCL:0;RULEID:;UriScan:;
    X-Forefront-PRVS: 03283976A6
    Received-SPF: Pass (protection.outlook.com: domain of ne.usda.gov designates
    199.135.140.13 as permitted sender) receiver=protection.outlook.com;
    client-ip=199.135.140.13; helo=mail.usda.gov;
    Authentication-Results: spf=pass (sender IP is 199.135.140.13)
    [email protected];
    X-OriginatorOrg: ne.usda.gov
    X-SA-Exim-Connect-IP: 157.56.111.79
    X-SA-Exim-Mail-From: [email protected]
    X-SA-Exim-Scanned: No (on joe.nabble.com); SAEximRunCond expanded to false
    –_000_CC7D70A42380404292EB449163C108D09E1DEA001FSN2MPN4161001_
    From: jadams [via HEC-RAS Help] [mailto:[email protected]=
    om]
    Sent: Friday, September 05, 2014 10:16 AM
    To: Watermolen, John – NRCS, LINCOLN, NE
    Subject: Re: System Runtime Interop Services Errors
    I just tried it with my data set and got the same error. I changed the out=
    put directory to a folder on my local machine (not on our server) and it wo=
    rked fine.
    low:
    http://hec-ras-help.1091112.n5.nabble.com/System-Runtime-Interop-Services-E=
    rrors-tp923p932.html
    To unsubscribe from System Runtime Interop Services Errors, click here.
    .naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
    bble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nab=
    ble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21=
    nabble%3Aemail.naml>
    This electronic message contains information generated by the USDA solely f=
    or the intended recipients. Any unauthorized interception of this message o=
    r the use or disclosure of the information it contains may violate the law =
    and subject the violator to civil or criminal penalties. If you believe you=
    have received this message in error, please notify the sender and delete t=
    he email immediately.
    Thanks<= /p>
     <= /p>
    via HEC-RAS Help] [mailto:ml-node+[email protected]]
    I just tried it with =
    my data set and got the same error.  I changed the output directory to=
    If you reply to this ema=
    il, your message will be added to the discussion below:
    http://hec-ras-help.1091112.n5.nabble.com/System-Runtime-Interop-Serv=
    ices-Errors-tp923p932.html
    click here.
    NAML
    or criminal penalties. If you believe you have received this message in er=
    ror, please notify the sender and delete the email immediately.
    –_000_CC7D70A42380404292EB449163C108D09E1DEA001FSN2MPN4161001_–
    #8918
    hello me to i have the same error Please help me
    #8919
    Harsh Shah
    Hi jwatermolen,
    I am facing the same problem. I am using ArcGIS10.3.1 and HEC-RAS 5.0.7. Did you get the solution for it?
    I have attached a screenshot of the error.
    Can you help me to solve this error?
    Thanks in advance
    Harsh Shah
