Welcome to the RAS Solution Forums HEC-RAS Help Subgrid Technique and Continuity equation
  • This topic has 2 replies, 413 voices, and was last updated 9 years ago by Anonymous.
  • #6218
    Hej!
    I just got through the equations in Hec-Ras Reference Manual. Some questions came up by understanding how the subgrid is considered in the equation of continuity (it’s equation number 2-128) in the reference manual.
    Does it mean that Hec-Ras is caculating term 1 for each cell of the DEM because there are varying H in each cell of the DEM? Otherwise I don’t get how the subgrid is considered.
    Thanks for your reply. If you don’t understand the question, I will try to express it differently.
    #10111
    If the continuity equation is not considered for each DEM-cell, how would it be possible to have computational cells which are half filled?
    #10112
    RAS pre-computes an elevation-volume table for each cell. So it knows the minimum elevation in the given cell and it knows the elevation for which the cell is completely wet. In between these two elevations it will compute some additional points so that for a given elevation it knows how much volume of water there is in the cell. This elevation-volume table is based on the sub-grid. For a large 2D area, it can take a while to compute, but it only needs to be computed once. (But it has to be re-computed if the mesh is adjusted, for instance.)
    If you go to RAS Mapper and right click on a cell and select Property > Cell Volume, you can see the elevation/volume relationship. It uses (or rather interpolates) this table for determining continuity when the cell is half filled. So when it is doing the 2D computations, it does not have to go back to the sub grid.
