Welcome to the RAS Solution Forums HECRAS Controller sub MonteCarloNValues()
  • This topic has 2 replies, 132 voices, and was last updated 6 years ago by Anonymous.
  • #8234
    Hi everyone,
    I am not expert (at all) of VBA and therefore my question is simple.
    I am trying to replicate the Monte Carlo code example which is in the book of Chris Goodell, but when i try to run the routine, the following message pops up:
    “Compile error: User-defined type not defined”
    and the following two code lines gets highlighted:
    yellow highlighted : Sub MonteCarsloNValues()
    blue highlighted: Dim typGeom As mSamples.TypeRasGeom
    I know there is some VBA reference to turn on but which one?
    Also, is it possible to adapt this code to a 2D simulation?
    Thank you
    #13612
    I managed to solve the issue of typGeom As mSamples.TypeRasGeom thanks to the “errata sheet” of Chris and adding the module for TypeRasGeom.
    I now have an issue with this part of the code:
    Dim typGeom As TypeRASGeom
    Dim blnGotIt As Boolean
    blnGotIt = GetRiversReachesNodes(typRASGeometry, RC)
    The problem is that GetRiversReachesNodes is not an existing Function.
    How does it works?
    #13613
    Keymaster
    Nic- the function GetRiversReachesNodes is one I wrote myself. It is in the book on page 84.
    Thanks for buying my book. Hope you are finding it useful!
    -Chris
