Welcome to the RAS Solution Forums HEC-RAS Help stormwater pipe network to be assigned as overflow 2D
  • #6605
    David G.
    Hi
    I am interested to know how to treat a storm water pipe system into overflow 2D precipitation at major storm in HEC RAS 2D
    I was thinking to use a stream segment and sub-catchment boundary as a 2D boundary to demonstrate overland flow.
    Or do I need to modify precipitation rate?
    #10857
    I need some help regarding adding the precipitation in the HEC-RAS. The constant inflow hydrographs are provided as input for the 2D domain, now the precipitation also needs to be added over the whole 2D domain. The precipitation data consisted of the single value like return period with intensity.
    1- In order to add 100-year return period value of 1-hr duration (intensity) is 30mm, How we can add it?
    2- What does the actual mean of time series of precipitation? Is it mean the accumulated rainfall?
    for example
    Date Simulation time Precipitation (mm)
    11-01-2019 07:00 00:00 30
    11-01-2019 08:00 01:00 30
    11-01-2019 09:00 02:00 30
    Does it mean the total rainfall added on the 2D flow area during the whole simulation time is 90 mm? Please elaborate?
    3- If we just want to add 30mm in total for the whole simulation time of three hours (as above), then is it a right approach?
    11-01-2019 07:00 00:00 10
    11-01-2019 08:00 01:00 10
    11-01-2019 09:00 02:00 10
