I was given a 2D HEC-RAS model developed by USACE, but several of the plans modeled had all WSE results uniform across the the entire domain (all at the initial condition/”downstream” B.C.
After trying several things, USACE suggested I just re-run the model. When I run the model the “Stored Map Generation” progress bar never turns blue, and the results I get are all the same as the results that USACE provided. If I go to a structure or a cross section, and look at the WSE time series, I see varying results, but mapper doesn’t reflect this.
Thoughts?
