Welcome to the RAS Solution › Forums › HEC-RAS Help › STORAGE AREAS
- This topic has 1 reply, 2,418 voices, and was last updated 10 years, 8 months ago by giacomo.
July 10, 2015 at 4:38 pm #5833giacomoParticipant
I’m quite new in Hecras, even If I studied lots of documents.
Actually I’m trying to do a very simple model, a short river flowing into a storage area in unsteady flow analsys.
My task is to understand how much the water level of the storage area increases during the time of the flood wave to understand if it overflows the dam or not.
In first hypotesis, the model is as simple as I told, later I’ll add a lateral structures and I have to verify the dam breach, but firstI have to fix problems here.Even if it’s so easy, when I do the simulation, It goes to the end but the resaults are not reasonable.
Just to try to find the problem, I did some try and now my input conditions are:
– upstream bundary condition as flow idrograph in the river of 0.1 m3/s for 2 hours (so very small – actually it’s not a proper river, it’s a channel of derivation from a river so not big)
– initial water level of the storage area at 317 m (I set volume/elevation storage, the dam top is at 318.50 m – just to better understand the volume from 317m to 318.50m is about 90’000 m3)The program runs, maximum error of 5,2 but it goes to the end but the postprocessor show me that almost immediately the level in storage increases to 318.75 so it overcomes (increasing 1.75 m). But that is not possible, because the volume brought in 2 hours for that flow is 720m3 that is nothing compared to the storage capacity!
I arrived to think that this problem could be due to the difference in hight between the last section upstream the storage (that is higher) and the initial water level in the storage. For example if I set the initial water level in the storage at 318.70 than the process increase it only of few cm!
Or eventually I thought that the program imposes as water level of the storage area the water elevation on the last section upstream (for continuity I think) and beasue this is higher, then the storage seems to be higher, even if the stock volume is risible.
Could I be right? And if so, is it possibile to avoid it? Maybe modifing some bundary conditions or adding a different section usptream the storage? Or using a sort of inline structure?
Actually I need to see the right increase in the storage area.
Thank you veru much for help
GiacomoJuly 10, 2015 at 9:05 pm #9431Chris G.KeymasterReturn-Path:
Received: from mail-pa0-f41.google.com (mail-pa0-f41.google.com [209.85.220.41])
by mwork.nabble.com (Postfix) with ESMTP id ED5922328347
for; Fri, 10 Jul 2015 09:05:42 -0700 (PDT)
Received: by pactm7 with SMTP id tm7so170503773pac.2
for; Fri, 10 Jul 2015 09:05:36 -0700 (PDT)
d=gmail.com; s=20120113;
bh=ZqSBh/wefNdWwvSlH2CWMnfNuxvLkZzkc9wvv05mDOE=;
b=oXRXkvDQyeO7gdTv5e+dVQ6oiLWhT0wEFJTkGDEZWDiRcLcsRO8tvmaLZ1/08WIfeJ
ke514325p/hnHiycZvi70jCuMr3zt680Sxf0Da5AP58TqgiJlKyvg7jlhBHDfaxJ0swp
Gf4JOEkab4kV9Eu61vlPgvOYuEcvxpt3Zq8R4LrypVlOsI78oDNGZ3iFlnGmpTZFe+VU
0nNqfEPNG7t41HejSMvhX0Vmo+beYyyZHiCzdxHIGyLi2YUpOz6wJPFVnoX5X6bnY1KR
Wg5ztx1o7BjJcbvuZR8dfn/bMtmfgIv4IlsNHFIHIGmyruI+Ab7KpqJN1OGWRCaiH2G8
pjOw==
X-Received: by 10.70.37.207 with SMTP id a15mr43510768pdk.4.1436544335833;
Fri, 10 Jul 2015 09:05:35 -0700 (PDT)
Received: from [100.79.65.38] (21.sub-70-210-137.myvzw.com. [70.210.137.21])
by smtp.gmail.com with ESMTPSA id fk5sm10055538pab.40.2015.07.10.09.05.33
for
Fri, 10 Jul 2015 09:05:34 -0700 (PDT)
Subject: Re: STORAGE AREAS
boundary=Apple-Mail-A111A840-712C-4BBF-975A-9750D7CAAEF8
X-Mailer: iPhone Mail (12D508)
Date: Fri, 10 Jul 2015 09:05:31 -0700
To: “giacomo [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-A111A840-712C-4BBF-975A-9750D7CAAEF8
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printablePlease read this post on The RAS Solution. It should help.=20
http://hecrasmodel.blogspot.com/2010/08/how-to-use-storage-area-to-define.ht=
ml?m=3D1Chris
Sent from my iPhone> On Jul 10, 2015, at 4:38 AM, giacomo [via HEC-RAS Help]
wrote:
>=20
> Hello,=20
> I’m quite new in Hecras, even If I studied lots of documents.=20
> Actually I’m trying to do a very simple model, a short river flowing into a=
storage area in unsteady flow analsys.=20
> My task is to understand how much the water level of the storage area incr=
eases during the time of the flood wave to understand if it overflows the da=
m or not.=20
> In first hypotesis, the model is as simple as I told, later I’ll add a lat=
eral structures and I have to verify the dam breach, but firstI have to fix p=
roblems here.=20
>=20
> Even if it’s so easy, when I do the simulation, It goes to the end but the=
resaults are not reasonable.=20
>=20
> Just to try to find the problem, I did some try and now my input condition=
s are:=20
> – upstream bundary condition as flow idrograph in the river of 0.1 m3/s fo=
r 2 hours (so very small – actually it’s not a proper river, it’s a channel o=
f derivation from a river so not big)=20
> – initial water level of the storage area at 317 m (I set volume/elevation=
storage, the dam top is at 318.50 m – just to better understand the volume f=
rom 317m to 318.50m is about 90’000 m3)=20
>=20
> The program runs, maximum error of 5,2 but it goes to the end but the post=
processor show me that almost immediately the level in storage increases to 3=
18.75 so it overcomes (increasing 1.75 m). But that is not possible, because=
the volume brought in 2 hours for that flow is 720m3 that is nothing compar=
ed to the storage capacity!=20
>=20
> I arrived to think that this problem could be due to the difference in hig=
ht between the last section upstream the storage (that is higher) and the in=
itial water level in the storage. For example if I set the initial water lev=
el in the storage at 318.70 than the process increase it only of few cm!=20
>=20
> Or eventually I thought that the program imposes as water level of the sto=
rage area the water elevation on the last section upstream (for continuity I=
think) and beasue this is higher, then the storage seems to be higher, even=
if the stock volume is risible.=20
>=20
> Could I be right? And if so, is it possibile to avoid it? Maybe modifing s=
ome bundary conditions or adding a different section usptream the storage? O=
r using a sort of inline structure?=20
>=20
> Actually I need to see the right increase in the storage area.=20
>=20
> Thank you veru much for help=20
> Giacomo=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/STORAGE-AREAS-tp1817.html
> NAML–Apple-Mail-A111A840-712C-4BBF-975A-9750D7CAAEF8
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitPlease read this post on The RAS Solution. It should help.
http://hecrasmodel.blogspot.com/2010/08/how-to-use-storage-area-to-define.html?m=1Chris
Sent from my iPhoneOn Jul 10, 2015, at 4:38 AM, giacomo [via HEC-RAS Help] <[email protected]> wrote:Hello,
Giacomo
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/STORAGE-AREAS-tp1817.html
NAML
–Apple-Mail-A111A840-712C-4BBF-975A-9750D7CAAEF8– -
