Welcome to the RAS Solution › Forums › HEC-RAS Help › step interpolation between 2 xs
- This topic has 8 replies, 844 voices, and was last updated 10 years, 9 months ago by mat A..
July 1, 2015 at 3:48 pm #5830mat A.Participant
i have two xs in 100 meters. The flow regime is supercritical.
In first time, i interpolated between this 2 xs with a distance of 10m, then ws elevation was stable, but i had a warning : i must add xs.
So , in second time i interpolated between the 2 xs with a distance of 1m, and then results in ws elevation were very different and become instable (multiple oscilations!) Same thing with lower step.My question is : how can i define the good interpolation’s step between xs? Is it possible that a very low interpolation’s step make oscilations in the water surface elevation?
Thank you for your help!
July 1, 2015 at 8:05 pm #9418AnonymousGuestHello,
May you share some print screens, such profile plot, boundary conditions?
July 2, 2015 at 11:04 am #9419mat A.ParticipantJuly 3, 2015 at 1:45 am #9420RobertParticipantHi Mat,
Why do you choose a interpolation 1 or 2 m? You should estimate a distance between cross section using Samuel equation and Fread’s euatione (see manual hec).
Can you send me your model? (using File- Debug report) I think, that you have more bugs in your model (ineffective area, abrupt change of bed of channel, …)
regards
RobertJuly 6, 2015 at 11:00 am #9421mat A.ParticipantThank you Robert!
I thought Samuel’s equation must be used in case of unsteady flow data (relation time step and xs interpolation step)?
I choose a low xs interpolation step because of warnings in cross section Output “…this may indicate the need for additional cross sections” I thought results always where best with a low step?
best regards.
July 6, 2015 at 11:08 am #9422mat A.ParticipantJuly 7, 2015 at 1:01 am #9423jadamsParticipantOddly I don’t seem to have the rapid oscillation when I run it on my machine. However I do still have the hydraulic jump after Section 130 for your higher flow profiles.
July 7, 2015 at 1:24 am #9424RobertParticipantHi Matt
Sorry, I am busy, therefore I write you today.
I was looking your model and your issue is a downstream condition (steady flow, reach boundary conditions).
Why did you choose a Know WS for the downstream condition? You cann´t use one WS for all flow (10,20,50, …)!!! You should use it, when you simulate one flow a you know a WS for this flow in the downstream cross section.
Do you understand me?I changed:
upstream condition: from 0.01 to 0.006 Normal depth
downstream condition: from Know WS to Normal depth 0.01Using URL I send you your edited model.
https://onedrive.live.com/redir?resid=76FE2B3DBFE48BD3!4657&authkey=!AHSbaEZxmdRgO2s&ithint=file%2czipI hope, that I help you 🙂
regards RobertJuly 7, 2015 at 10:45 am #9425mat A.ParticipantHello,
OK for downstream condition, thanks! (My interest is near the bridge, downstream condition is far enough).
Sorry, oscillations appears with 0.5m step interpolation, under 1 m. (it’s also depending on manning value).
In this model, measuring station is unfortunately located near the bridge on supercritical flow, that’s why i must interpolate with very low step, and i founded that oscillation problem.
Best regards.
