Welcome to the RAS Solution Forums HEC-RAS Help Steady vs Unsteady flow results
  • #6501
    Arthur Barboza
    Hi everybody,
    I am having a little trouble while running steady and unsteady flow simulation.
    In the steady state, my results match with observed WS elevations all along the reach. But, if I run an unsteady simulation (constant flow and boundary condition exactly the same as in steady state), two “waterfalls” appears in the middle of the reach, giving me WS elevations way higher than observed data.
    Does somebody have a clue about what might be happening? I know HEC-RAS solve steady/unsteady simulation with different routines and equations, but I wouldn’t expect such a big difference in Froude number and others hydraulic properties that affects the WS elevation.
    Arthur
    #10644
    Did you adjust the Htab parameters? Are there any structures in the model? Do the hydrographs at any of the structures look funny? Have you tested different timesteps? Do you get any errors when running in unsteady?
    #10645
    Arthur Barboza
    Return-Path:
    by sloti25t09 (Cyrus fastmail-fmjessie44146-15201-git-fastmail-15201) with LMTPA;
    Wed, 14 Jun 2017 09:03:38 -0400
    X-Cyrus-Session-Id: sloti25t09-3904879-1497445418-2-11815831314952501903
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 1.9
    X-Spam-hits: BAYES_50 0.8, HTML_MESSAGE 0.001, RCVD_IN_MSPIKE_H3 -0.01,
    RCVD_IN_MSPIKE_WL -0.01, SPF_PASS -0.001, URI_HEX 1.122, LANGUAGES en,
    BAYES_USED global, SA_VERSION 3.4.0
    X-Spam-source: IP=’189.126.112.57′, Host=’hm1831-37.locaweb.com.br’, Country=’BR’,
    FromHeader=’br’, MailFrom=’br’
    X-Spam-charsets: plain=’iso-8859-1′, html=’iso-8859-1′
    X-Attached: image001.gif
    X-Attached: image002.jpg
    Received: from mx6 ([10.202.2.205])
    by compute1.internal (LMTPProxy); Wed, 14 Jun 2017 09:03:38 -0400
    Received: from mx6.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id C06C543788
    for ; Wed, 14 Jun 2017 09:03:37 -0400 (EDT)
    by mx6.messagingengine.com (Authentication Milter) with ESMTP
    id FF1DF2E8970;
    Authentication-Results: mx6.messagingengine.com;
    dkim=none (no signatures found);
    dmarc=none (p=none) header.from=hicon.com.br;
    spf=pass [email protected] smtp.helo=hm1831-37.locaweb.com.br
    Received-SPF: pass
    (hicon.com.br: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:_spf.locaweb.com.br’ matched))
    receiver=mx6.messagingengine.com;
    identity=mailfrom;
    helo=hm1831-37.locaweb.com.br;
    client-ip=189.126.112.57
    Received: from hm1831-37.locaweb.com.br (hm1831-37.locaweb.com.br [189.126.112.57])
    by mx6.messagingengine.com (Postfix) with ESMTP
    for ; Wed, 14 Jun 2017 09:03:34 -0400 (EDT)
    Received: from mcbain0014.correio.biz (189.126.112.17) by hm1831-n-113.locaweb.com.br id h84q2g15ctoo for ; Wed, 14 Jun 2017 10:03:32 -0300 (envelope-from )
    Received: from proxy.email-ssl.com.br (bartf0033.email.locaweb.com.br [10.31.120.65])
    by mcbain0014.correio.biz (Postfix) with ESMTP id A6D28380331
    for ; Wed, 14 Jun 2017 10:03:31 -0300 (BRT)
    x-locaweb-id: gltuLfKInbwOaigsZfjUD6RGdYFV7R7MPpCFHiuykuDUK_BdhbzFRWG2IOdkBLH-oSFasVCJa9NoQmiblMnGLitmwI88DCbVReR2RDRDSbbXMbAcivo6gcCSNrCWJbeDLJim_IhIqnB2ldrWAC0FiSLFOvcnA3DNIXHRUE-dj8AAfT41AAbDvi3dxeRl3V4RHD9z0GnCia4ZAMp_eWYsvg== NjE3Mjc0Njg3NTcyNDA2ODY5NjM2ZjZlMmU2MzZmNmQyZTYyNzI=
    X-LocaWeb-COR: locaweb_2009_x-mail
    X-AuthUser: [email protected]
    Received: from Optiplex360PC (unknown [201.76.176.122])
    (Authenticated sender: [email protected])
    by proxy.email-ssl.com.br (Postfix) with ESMTPSA id 6B4882106D
    for ; Wed, 14 Jun 2017 10:03:30 -0300 (BRT)
    To: “‘cameron [via HEC-RAS Help]'”
    Subject: RES: Steady vs Unsteady flow results
    Date: Wed, 14 Jun 2017 10:03:29 -0300
    Message-ID: <[email protected]>
    MIME-Version: 1.0
    Content-Type: multipart/related;
    boundary=”—-=_NextPart_000_0003_01D2E4F5.79802F50″
    X-Mailer: Microsoft Outlook 16.0
    Thread-Index: AQLKHt394N+4S9wSs1jTiVSlzb+RkAJL6tqIoCN/SOA=
    Content-Language: en-us
    X-Antivirus: avast! (VPS 170613-0, 13/06/2017), Outbound message
    X-Antivirus-Status: Clean
    This is a multipart message in MIME format.
    ——=_NextPart_000_0003_01D2E4F5.79802F50
    boundary=”—-=_NextPart_001_0004_01D2E4F5.79802F50″
    ——=_NextPart_001_0004_01D2E4F5.79802F50
    Content-Type: text/plain;
    charset=”iso-8859-1″
    Thanks a lot Cameron! I solved it by adjusting the HTab Parameters, they
    were default.
    =20
    =20
    Arthur Prado Barboza
    Engenheiro Ambiental | [email protected] =
    Av. Rio Branco 20, 13=BA andar Centro
    20090-000 Rio de Janeiro RJ Brasil
    +55 21 2576-6090 | <http://www.hicon.com.br/> http://www.hicon.com.br
    Antes de imprimir, pense em sua responsabilidade
    =20
    De: cameron [via HEC-RAS Help] =
    [mailto:[email protected]]=20
    Enviada em: Wednesday, June 14, 2017 12:36 AM
    Para: Arthur Barboza
    Assunto: Re: Steady vs Unsteady flow results
    =20
    Did you adjust the Htab parameters? Are there any structures in the =
    model?
    different timesteps? Do you get any errors when running in unsteady?=20
    _____ =20
    If you reply to this email, your message will be added to the discussion
    below:
    http://hec-ras-help.1091112.n5.nabble.com/Steady-vs-Unsteady-flow-results=
    -tp
    4066p4069.html=20
    To unsubscribe from Steady vs Unsteady flow results, click here
    <http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?macro=
    =3Dun
    subscribe_by_code&node=3D4066&code=3DYXJ0aHVyQGhpY29uLmNvbS5icnw0MDY2fDE1=
    NjM1MDY
    xNjQ=3D> .
    =20
    =3Dma
    cro_viewer&id=3Dinstant_html%21nabble%3Aemail.naml&base=3Dnabble.naml.nam=
    espaces
    .BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.=
    tem
    plate.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%3Aemail.nam=
    l-ins
    tant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.nam=
    l>
    NAML=20
    Content-Type: text/html;
    Thanks a lot Cameron! =
    I solved it by adjusting the HTab Parameters, they were =
    default.
    [email protected]
    3D"Descri=E7=E3o:
    Av. Rio Branco 20, 13=BA =
    andar   Centro
    20090-000   Rio de =
    Janeiro   RJ   Brasil
    +55 21 2576-6090 =
    &nb=
    sp;
    3D"Descri=E7=E3o:
    An=
    Enviada em: =
    Para: Arthur Barboza =
    <[email protected]>
    Assunto: Re: Steady vs Unsteady =
    flow results
    Did you adjust the Htab =
    parameters?  Are there any structures in the model? Do the =
    hydrographs at any of the structures look funny?  Have you tested =
    different timesteps?  Do you get any errors when running in =
    unsteady?
    I=
    f you reply to this email, your message will be added to the discussion =
    below:
    <= a = href=3D"http://hec-ras-help.1091112.n5.nabble.com/Steady-vs-Unsteady-flow= -results-tp4066p4069.html">http://hec-ras-help.1091112.n5.nabble.com/Stea=
    dy-vs-Unsteady-flow-results-tp4066p4069.html =
    T=
    o unsubscribe from Steady vs Unsteady flow results, click here.
    NAML =
    ——=_NextPart_001_0004_01D2E4F5.79802F50–
    Content-Type: image/gif;
    name=”image001.gif”
    Content-ID:
    R0lGODlhygBaAPcAAP///xNeq4mu1U6GwE6PzMTX6vD1+iJosKbC3+Hr9NPh7z98uzFytl2RxWyb
    y5e42rXM5Xul0NPj8qbH5VmWz3qr2ZG532+k1vT4/Onx+bzV7GSd0rHO6Yay3Mfc75zA4t7q9QAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C01TT0ZGSUNFOS4wFwAA
    AAttc09QTVNPRkZJQ0U5LjBCPKT1ACH/C01TT0ZGSUNFOS4wGAAAAAxjbVBQSkNtcDA3MTIAAAAD
    SABzvAAsAAAAAMoAWgAACP8AAQgcSLCgwYMIEypcyLChw4cQI0qcSLGixYsYM2rcyLGjx48gQ4oc
    SbKkyZMoU6pcybKly5cwY8qcSbOmzZs4c+rcybOnz59AgwodSrSo0aNHEQxYynRAAwECHhRQgLTq
    SgEBsmrdupXBAAEFDFgdGxIr17NoBzxIQLatRrNo43JdgECs27sS4crdm/WAALt4Ay/Uy5evX8At
    zw64iFZwQaUOoEqevJRB4b4IXipmfNYxRQUIIgzgO4Aqy80WG3u+CCGC5bgCTnNdnLrz6owFHBxI
    i9gk6oqqb2c0IGA31wOmT/6mGFy4wAwSokuXALH42czKZ19sylS4BAsVCIj/H09e/IYKHzSAUGgg
    wtkH2bfSdr5xQvn7+AlQ6MAhA8ICr2nlgG/a0VdffgjedwEHGBhkgANcDUjScgZeZF+CGJJnAXWP
    RThhgQAUIIAD3EUAgUIFpKhiAQtBIAB3S0UGQXIHGeAijA48QONBCqyYIkEJIEBiUwLsSNCFGSZJ
    QAUcDqSAcVkN0FtHiimg214MnHhQcwQRB+VeBxyUwJV70ZXQaFwJpNRepR2EZAUWTKDBdNJpMAF4
    GTIJ5AJbLTDlRpfJhV1BXAqkQICXGYTAl6T9ieZWCCAqF3IG2dmkQyBw0EGCFjQokAGPBuAnSIHK
    xSKhthH0ZKlZFeQeq6JO/xkqrAEw8KdFHmyKHwUeEAShVgsYmRGtIA7EpQGSJjoQBMSKatCstA7K
    EQYTbIDfB54C8GpfwnLWbFY7cklYoAMZwCirsREELazzfaSBteVd4J+aWx0g7bBoHeAAAqeG2ABa
    6RqbqkDnBjAAv06qCNVA4wZwQARTJVDAmmcdgNi6UYIllgGLFupgipNJBkFYC3FAQXm8DlTAlxFw
    dFaWZ1LYHLNnSdhQsguwZdADaEkLLV1/FoCWsAoI0EDBFX/Vb0EYWHDfBE7yqdUAOmNEYUE094lq
    mgNtqxUDDykwdEL/ejgQtEsblOzSYyJ9mb5aFiQBvON1+mnZfcFndbEOcv/ZHLT3KoTAWQ0oJDZX
    YJ99VtoFoU1Qw8Qy8BfTTpMn70APfLkA4xFdvfVWn2tF0LlVMzSu3gmdq+7iCjnO8Lf5Tk6QByeP
    l7JACcwKdEIKRIB66AYv5PfAHpPNeutnVe06QssDADnsfhWUwQXlfUBQx3M9JRmJWgUMfLtbDgxA
    c8Uzf3zMXPXb/LPnOw87lml/EO+8ABCXrFzeE+S5/uKTPxdE62Nf+hQ3QPRtZWnPe19WHIAY2pGH
    Ahx4DN4mFTiB7E9gXMMg6DQYJQC27yDLC+DqCiiQBCrQYXEDAAbCY7lLCUREDSiRVBRyQQv2j3h8
    W4gIR3hAAvbQgFpB4An/C9MAxJisPHram3yEd8MMji+HyCOh+Ui4Q4E0z4RDdJi0MqAr8mygPwvB
    wJwQUsMnOtGMG7ThGXX4QQH+EABVhGP7sJhFg5VubvjZQAcmMAHp8LED1CMA1MK3RBo2MY1oFN1D
    4ihHKraRh0F8XB3flj8NBFJJ4hmkQco4PCeW7yBey0oKD5IsSGaFcz6M5OsmeRkG3Os7tUuSJr/H
    xDP+7ZEIGVfLEmKAW0rRjaosIStLNQDGSWACgLzPedKzHjJCkX+2HNgEF/gQoSFOITwrVhyvOExW
    ufJWE+HkIRUpkGxypVt9O0v+ynUu721zjt2kVQMQUDoUdUuc0XRiAvJV/8GDTDMrEegNgNBSundK
    kY7xRAsDniIVFbnoRVJbpxqnVktEJrJVBPlnVrwimaZgNERyidEA7hc8UwYAlVaEZ0LjKdGLgm+T
    4/yooYiV0W/tyKBvdN9Ku9lSfFq0UAhFJLKIFTicBlOnO2VlT5/JQZleNAAH+VWpCpIAqZWqgkY9
    pSSTqlRnFjIhnbToQLCnrC6FUi4MQGVWT0oQEYXsrXCNq1znSle6ovKt/WTYWwsCV14+wKpoWUCO
    EJIAAQC2Xg4Y5WPeWs/FhqyxFRqJj1IEzoNMFrKRzaxmN8vZznr2s6ANrWhHS1qHFBazKGrpf1S7
    k9Me5AG/cx7jRCQUof+hNCFYqQ5Uh2Jbg0BolAFYZ26D0tuISEy3RCmuyg62yXUeVyMJEE1iXwgW
    0QQUdy8awL5wJ91TiSg3A7iu0CJAous6L4bbBQACYDtP2p7XKfciDlN2a4AHwLcgExNSZsAbgaoh
    IIb9dW2I0gWWFwEAAiR6Cne1eyr5hrdf4y2vXcCiJvQGV73s5Ve62rOUdP33K3YBr4K7dIADDIBP
    JzLLUgJQOHPpSzeLSUCJTxyAFEdpNAOy5ooLB8cGRIBPLBqNiREwXKf8OADSWsABGtAAywiETyve
    pTANhgBmLWAAJRaLewRbmuIOd6OlEdWQACBjE1vmREdjMnNfeGMWWzD/NlhZgGguLOSDDVfJanbf
    lbO8TwaIBnw8M82J3aezJgMg0FZcDM90dmVCJxqkp3JPQXoZm0ELs7kqQ/KlhYYdSTNsVABYwAJw
    FwD4LLmtbHWfBbEjtBS6h9GjtjR+U+3pC4vaWJUe9aZrPDoeC00qvD4IVlQEIVVferhwXEyTiQ1V
    ZC8F0pcm8wOgQuf5DDcB08ZKwLzc7JOmiGf9MrAFHaCihY7Pe9y24KnKLLtnX9o9xZz1qb4cmwu/
    OdmvMzauce1iATR2XPrOrbMXAy19PzvdQvPKaCptbajKWOH2hraqxxXu+Wwm4hL/cr/GpEV8RztS
    BgNMus9N8nu7e+K7/zVW3C78oKzkTwCJk2S+Bw6ABuha5o9ON1bsUu2ZB4Dn2061wFNuEHGXXH/o
    FvpuUz2QBPxLAbL2tJpOzeZ5L73eAev5pXmGmIhHvOU04tkokZ3bwWHn2eDma8oPrnT3iWWfDPf5
    xiIutnQV+9e5nM8CbFUQr4ic105fOuOYVQBEI4vHA2l01aNta77D3eOqFtvvGDAqnkmL8F3i0wEs
    sxiyQ9UAfGIA5+tnGdEHj+YIrxWa4n5psXnF5atjgHFSegCpPW4+NFPyhQdnYrZaxqrqZjPla2UA
    0DvMYVQZDZY1vXhjX5hmr2G9sf9levVqLeGa742NoIIAqjyXzP16qInity+A7oPfSVQxAMnOD4Ci
    6agAbFFAcp5btCIpoJ4u6j6EoTLDptMI21ABATpTf3UhbUXyXOunftxnFxwTFQNIZEXSJeuHgAMI
    FT0Sf/MXfgGIO9OmJQpYfpX1EIdXWgZiTVqhWCToGT1CWSnYgi74gjAYgzI4gzRYgzZ4gziYgzq4
    gzzYgzkYEAA7
    Content-Type: image/jpeg;
    name=”image002.jpg”
    Content-ID:
    /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwgHBgoICAgLCgoLDhgQDg0NDh0VFhEYIx8lJCIf
    IiEmKzcvJik0KSEiMEExNDk7Pj4+JS5ESUM8SDc9Pjv/2wBDAQoLCw4NDhwQEBw7KCIoOzs7Ozs7
    Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozv/wAARCAApABsDASIA
    AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA
    AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3
    ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm
    p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA
    AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx
    BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK
    U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3
    uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD1XW9b
    s9B097u8lVR0RM8u3YCvP5viNq927PbJDbQgdNu9vrXSeMvB1z4purR479LaOBSGDIWJyeormdb8
    DNoWkyX8l2k8UQxIqgxsckAEckZ56cVyV1Wl8Dsjmqqq/h0NLTPiFco0a6jbrKj8CSIYY++Old+r
    B0DDowyK82s/h7fm5RLm4KQMufMgIbacdOa6qz8Pajb2kcL61cMyDGVbj9RUUHXjfnVxUXVXx6j/
    ABf4kTw1pH2gKHuJTshT1PqfYV5fb2t54u1Mf2hPNMrnc6s52qB/Ku0+Ilml1dacs4PlMrqD6Nwf
    zxXJW0s+i3cn2STc0eULFeG/CsMXVkpW6HPi6soSS6HaaPDPoo8uAMkS/wALSl1f8O1dhFKs0SSx
    nKOAwPtXD2upSz+Hmupgplwy88Bj2rpvDiTJ4esllOG8oHn07fpWmEqNy5fK5vh6nNp8ybWNJg1m
    wNrMSpBDRuOqMOhrzt/BGt2txIjIJkJJWSMk7s+o7V6nSGuqrh4VdzWrRjUXvHB6X4Nv59kWoP5V
    mr7zGG5Y/Su8VQqhVGABgAdqWiijQhSXujp0o01aJ//Z
    ——=_NextPart_000_0003_01D2E4F5.79802F50–
