Welcome to the RAS Solution Forums HEC-RAS Help Stations backwards?
  • This topic has 7 replies, 1,596 voices, and was last updated 6 years ago by Anonymous.
  • #7344
    I am working on a research project and while I was successful on two other streams having done nothing different, I have one that is acting strange in HEC-RAS. I am using HEC-GeoRAS, and everything exports fine, but the direction of flow always appears to be reversed in HEC-RAS. I have used the two tools to reverse this: GIS Tools>Reach Invert Lines Table>Reverse Order, and this appears to make the stream direction flip but the analysis still turns out totally wrong either way the arrow is facing. It appears the station order is flipped, so the profile plots for steady flow analysis always look like a giant pool. There is a profile line headed down and right, but the entire space to the right of the line is filled with blue water.
    So far I’ve tried messing with the flows and boundary conditions, I’ve re-drawn everything backwards and forwards and used flip line tools in GIS, I’ve used the “reverse XS Stationing and Cut Line Data” tool, but have not fixed this problem. I think it’s something with the stationing? The highest station numbers are always downstream, with the lowest upstream, and I can’t get those numbers to go in the opposite direction. Help would be greatly appreciated!
    Liz
    #12329
    in the geometry window you can right click and change the viewing options
    you can show the reach direction and cross-section direction
    cross-section direction should always be left to right – looking downstream
    highest stations should be upstream, and decreasing going downstream
    also double check that the profile of the reach invert is actually decreasing in elevation along the reach line
    hope any of these help
    #12330
    The cross sections are drawn left to right, but the river runs South to North making downstream at the top of the page… is this still the XS orientation I want?
    #12332
    Also, the stationing is backwards with the highest downstream and lowest upstream, but I’m not sure how to change that. Any suggestions?
    The profile of the reach invert is decreasing with main channel distance.
    #12333
    gerardo
    Hi.
    try these sequences:
    1) geometry data
    2)gis tools
    3)reach invert line table
    4) reverse order
    good luck
    Any problem asks again
    #12331
    gerardo
    If your river runs from south to north, your XSs go from West to East
    si tu rio corre de sur a norte , tus perfiles van de Oeste a Este
    #12334
    Unfortunately I tried this and it still doesn’t work, the stations remain the same. However, is the text in the table supposed to turn red before you hit ok?
    #12335
    gerardo
    If you want, send me your file to [email protected]. So I see how to help you.
    Gerardo
