Welcome to the RAS Solution › Forums › HEC-RAS Help › Standard Step Calculation
  • #5762
    Robert
    Hi
    Which direction do Hec-RAS calculate a WSE for single cross-sections? (from downstream to upstream or from upstream to donwstream)
    I found in the Reference Manual:
    1. The Bridge, Super Critical Flow- from downstream to upstream
    Can you explain me this Principle?
    thank you
    Robert
    #9232
    The way the steady flow computations proceed is from downstream to upstream for subcritical flow and from upstream to downstream for supercrical flow. For possible mixed flow regimes, both profiles are computed. The basics of this type of computation are given in http://pubs.usgs.gov/twri/twri3-a15/pdf/TWRI_3-A15.pdf.
    #9233
    Robert
    GD,
    I studied your document, but this is only steady flow (sub, super-critical and mixed).
    What direction does hec-ras compute, when i solve unsteady flow (gradually or rapidly varied flow)? I was looking also other documents, but i found nothing
    thank you very much
    regards
    Robert
    #9234
    Sorry, I interpreted your question to refer to steady flow. The step-backwater procedure is only for steady flow conditions. For full unsteady flow (St. Venant Eqs.) the unknowns (stage and discharge) are solved simultaneously at each computational point, stepping forward in time. The actual computations involve solving a non-linear matrix by iteration at each time step. So, there is not an upstream/downstream computation for unsteady flow. The formation of the matrix is described in detail in the HEC-UNET manual.
    Michael
