Welcome to the RAS Solution Forums HEC-RAS Help stage hydrograph
  • This topic has 1 reply, 1,609 voices, and was last updated 10 years ago by Anonymous.
  • #5856
    I am using reach length of 200km with slope=0.004 of rectangular cross section width 100m and using stage hydrograph as boundary condition of upstream. I couldn’t RUN it as it shows “Stage (s) in time series data are below the cross section minimum”. so is it necessary to add elevation in stage data or what may be the problem.
    #9471
    user
    Your lowest point of your cross section is simply lower than the stage hydrograph. You will have to specify a higher stage value.
