Welcome to the RAS Solution Forums HEC-RAS Help Splitting 2D Area into multiple areas
  • This topic has 3 replies, 707 voices, and was last updated 10 years ago by Anonymous.
  • #6010
    Does anyone know if there is a way to split a single 2D Area into multiple smaller 2D areas without losing most of your mesh edits?
    Thanks ahead of time!
    #9738
    Vince Moody
    There’s no way to do this natively within RAS. However, you can copy the XY data of your mesh computation points to the clipboard and into Excel for parsing. After you create the two 2D areas, you can paste the relevant XY points for each within the 2D Flow Area Editor. Not exactly straightforward, but totally doable. All the easier if you’re GIS savvy.
    #9739
    Great idea, I will try that out. Thank you!
    #9740
    Just to follow up… This method worked great and was relatively easy using GIS. Thanks!
