Welcome to the RAS Solution Forums HEC-RAS Help Snapshot of Results
  • This topic has 2 replies, 743 voices, and was last updated 6 years ago by Anonymous.
  • #7557
    Hi Group,
    I’m new to HEC-RAS and running a 2D model. While the model computations are going, what does this button at the bottom do: “Take Snapshot of Results”?
    The simulation will take several hours to finish. Is it possible to view the results in RAS Mapper before the simulation ends (and without stopping it)?
    I couldn’t find anything in the manuals.
    Thank you!
    #12658
    ckatsoulas
    Just press it and see what happens…. sometimes you need to take risks and suffer a little to learn… the suffering makes sure the learning is embedded in the brain for life…
    #12659
    – Let’s say your RAS model was called ‘BigLake’
    – Your first plan would be named ‘BigLake.p01’
    – The results file for your first plan (the file that the RasMapper application displays as depth/velocity/WSE rasters) would be called ‘BigLake.p01.hdf’ when the solver finished the simulation
    – Pressing ‘snapshot of results’ during simulation would create a special file called ‘BigLake.p01.snapshot.hdf’ and save it in the same folder with the plan file and the results file
    – This is a results file that contains data only to the point in time when you pressed ‘snapshot of results’
    – If you rename the ‘BigLake.p01.snapshot.hdf’ to ‘BigLake.p01.hdf’, the mapper will read the snapshot results
