Welcome to the RAS Solution Forums HEC-RAS Help Small Dam Sunny Day Breach Failure Question
  • This topic has 1 reply, 188 voices, and was last updated 7 years ago by Anonymous.
  • #7146
    Hello All,
    I am relatively new to the dam breach analysis and wanted to verify the results of my model for a “sunny day” failure. The input parameters are summarized below:
    Pond Depth = 16 feet
    Dam Top Elevation = 2970 ft
    Bottom Pond Elevation = 2954 ft
    Dam Sideslopes = 2H:1V
    Dam Top Width = 30 ft
    8″ Outlet Spillway Pipe Invert = 2967.33 ft
    Volume @ Spillway = 14.55 acre-feet
    WSEL @ piping failure = 2968 ft
    Failure Time = 0.32 hrs
    Breach Sideslopes = 0.5H:1V
    Breach Bottom Width = 43 feet
    The output I got from HEC-RAS was a Peak Q = 921 cfs.
    Does this sound or seem correct?
    Thank you for your time,
    #11972
    Scott Miller
    Consider doing calculations from a state or federal Dam Safety Office manual, to see if the results are on par.
    The Washington Department of Ecology has a Dam Breach Calculation Spreadsheet.
