Welcome to the RAS Solution Forums HEC-RAS Help Single Stream/Stead Flow Culvert
  • This topic has 2 replies, 220 voices, and was last updated 11 years ago by Anonymous.
  • #5713
    Its been awhile since I have modeled with HEC-RAS and have previously done simple single stream models and I am struggling with a seemingly easy model.
    I have an existing stream channel of approximately 500 feet with an existing culvert around 400 feet down stream.
    I feel like I have the model set up correctly but it gives an obviously incorrect result showing the stream over topping my roadway bu 7-8 feet even under small 1-years (which we know is not happening in the field).
    I have attached the project file – can anyone point me in the right direction?
    Thanks in advance!
    https://www.dropbox.com/s/3y4n96pb96icw4z/ReichesFordRoad_E.p01.zip?dl=0
    #9139
    markwood
    Return-Path:
    Received: from na01-by2-obe.outbound.protection.outlook.com (mail-by2on0086.outbound.protection.outlook.com [207.46.100.86])
    by mwork.nabble.com (Postfix) with ESMTP id 11ED71498B44
    for ; Sat, 21 Feb 2015 12:05:20 -0800 (PST)
    Received: from DM2PR03CA0044.namprd03.prod.outlook.com (10.141.96.43) by
    BY2PR03MB208.namprd03.prod.outlook.com (10.242.36.156) with Microsoft SMTP
    Server (TLS) id 15.1.93.12; Sat, 21 Feb 2015 20:05:10 +0000
    Received: from BL2FFO11FD039.protection.gbl (2a01:111:f400:7c09::143) by
    DM2PR03CA0044.outlook.office365.com (2a01:111:e400:2428::43) with Microsoft
    SMTP Server (TLS) id 15.1.99.9 via Frontend Transport; Sat, 21 Feb 2015
    20:05:10 +0000
    Received: from USDEN3EXHT002.na.aecomnet.com (65.240.194.57) by
    BL2FFO11FD039.mail.protection.outlook.com (10.173.161.135) with Microsoft
    SMTP Server (TLS) id 15.1.99.6 via Frontend Transport; Sat, 21 Feb 2015
    20:05:09 +0000
    Received: from USDEN3EXMB002A.na.aecomnet.com ([169.254.13.78]) by
    USDEN3EXHT002.na.aecomnet.com ([172.27.132.57]) with mapi id 14.03.0210.002;
    Sat, 21 Feb 2015 12:05:08 -0800
    To: “Andy [via HEC-RAS Help]”
    Subject: RE: Single Stream/Stead Flow Culvert
    Thread-Topic: Single Stream/Stead Flow Culvert
    Thread-Index: AQHQTev6I/W0cRZ3TEqbmeO+GZqYKZz7hs6w
    Date: Sat, 21 Feb 2015 20:05:08 +0000
    Message-ID: <6E5E1A75787CA14E9AB482FF2FFE6A715A71D30D@USDEN3EXMB002A.na.aecomnet.com>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    x-originating-ip: [192.168.220.62]
    x-aecom-disclaimer: Yes
    boundary=”_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71D30DUSDEN3EXMB002An_”
    MIME-Version: 1.0
    X-EOPAttributedMessage: 0
    Received-SPF: None (protection.outlook.com: aecom.com does not designate
    permitted sender hosts)
    Authentication-Results: spf=none (sender IP is 65.240.194.57)
    [email protected]; n5.nabble.com; dkim=none (message not
    signed) header.d=none;
    X-Forefront-Antispam-Report:
    CIP:65.240.194.57;CTRY:US;IPV:NLI;EFV:NLI;SFV:NSPM;SFS:(10009020)(428002)(199003)(189002)(51874003)(377454003)(104016003)(2900100001)(2920100001)(2950100001)(77156002)(62966003)(19580395003)(6806004)(77096005)(19580405001)(110136001)(92566002)(2656002)(15975445007)(102836002)(450100001)(512954002)(105586002)(64706001)(19617315012)(106116001)(19300405004)(14971765001)(101416001)(33656002)(86362001)(87936001)(19625215002)(107886001)(50986999)(54356999)(84326002)(76176999)(106466001)(16236675004)(5890100001)(19626265003)(5310100001)(46102003)(55846006);DIR:OUT;SFP:1101;SCL:1;SRVR:BY2PR03MB208;H:USDEN3EXHT002.na.aecomnet.com;FPR:;SPF:None;PTR:ip-65-240-194-57.den3.us.aecom.com;A:1;MX:1;LANG:en;
    X-Microsoft-Antispam: UriScan:;
    X-Microsoft-Antispam: BCL:0;PCL:0;RULEID:;SRVR:BY2PR03MB208;
    X-Microsoft-Antispam-PRVS:
    X-Exchange-Antispam-Report-Test: UriScan:;
    X-Exchange-Antispam-Report-CFA-Test:
    BCL:0;PCL:0;RULEID:(601004)(5005003);SRVR:BY2PR03MB208;
    X-Forefront-PRVS: 049486C505
    X-Exchange-Antispam-Report-CFA-Test: BCL:0;PCL:0;RULEID:;SRVR:BY2PR03MB208;
    X-OriginatorOrg: aecom.com
    X-MS-Exchange-CrossTenant-OriginalArrivalTime: 21 Feb 2015 20:05:09.9724
    (UTC)
    X-MS-Exchange-CrossTenant-Id: f205a70a-ddf9-44aa-bf6c-2c222d9d1bfc
    X-MS-Exchange-CrossTenant-OriginalAttributedTenantConnectingIp: TenantId=f205a70a-ddf9-44aa-bf6c-2c222d9d1bfc;Ip=[65.240.194.57]
    X-MS-Exchange-CrossTenant-FromEntityHeader: HybridOnPrem
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BY2PR03MB208
    –_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71D30DUSDEN3EXMB002An_
    Andy,
    It looks like the XS’s are in reverse. That is, RS 544.46 is the first XS i=
    n the model (or intended to be), yet it has the most-upstream River Station=
    Let me know if that isn’t helpful.
    From: Andy [via HEC-RAS Help] [mailto:[email protected]=
    m]
    Sent: Saturday, February 21, 2015 10:35 AM
    To: Markwood, David
    Subject: Single Stream/Stead Flow Culvert
    Its been awhile since I have modeled with HEC-RAS and have previously done =
    simple single stream models and I am struggling with a seemingly easy model=
    I have an existing stream channel of approximately 500 feet with an existin=
    I feel like I have the model set up correctly but it gives an obviously inc=
    orrect result showing the stream over topping my roadway bu 7-8 feet even u=
    I have attached the project file – can anyone point me in the right direct=
    ion?
    Thanks in advance!
    https://www.dropbox.com/s/3y4n96pb96icw4z/ReichesFordRoad_E.p01.zip?dl=3D0
    low:
    http://hec-ras-help.1091112.n5.nabble.com/Single-Stream-Stead-Flow-Culvert-=
    tp1343.html
    To start a new topic under HEC-RAS Help, email [email protected]=
    ble.com
    To unsubscribe from HEC-RAS Help, click here<http://hec-ras-help.1091112.n5=
    .nabble.com/template/NamlServlet.jtp?macro=3Dunsubscribe_by_code&node=3D1&c=
    ode=3DZGF2aWQubWFya3dvb2RAYWVjb20uY29tfDF8LTE3NzA3MjE4MzI=3D>.
    .naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
    bble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespac=
    e-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleName=
    space-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.Nabble=
    Namespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subsc=
    ribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_inst=
    ant_email%21nabble%3Aemail.naml>
    This e-mail and any attachments contain AECOM confidential information that=
    may be proprietary or privileged. If you receive this message in error or =
    are not the intended recipient, you should not retain, distribute, disclose=
    or use any of this information and you should destroy the e-mail and any a=
    ttachments or copies.
    Andy,
    It looks like the XS’s =
    are in reverse. That is, RS 544.46 is the first XS in the model (or intende=
    d to be), yet it has the most-upstream River Station.
    Let me know if that isn&#8217=
    ;t helpful.
    a HEC-RAS Help] [mailto:ml-node+[email protected]]
    To: Markwood, David
    Its been awhile since=
    I have modeled with HEC-RAS and have previously done simple single stream =
    I have attached the project file  – can anyone point me in the right d=
    irection?
    Thanks in advance!
    https://www.dropbox.com/s/3y4n96pb96icw4z/Reich=
    If you reply to this ema=
    il, your message will be added to the discussion below:
    htt=
    p://hec-ras-help.1091112.n5.nabble.com/Single-Stream-Stead-Flow-Culvert-tp1=
    343.html
    ml-node+s109=
    [email protected]
    click here
    NAML
    This e-m=
    ail and any attachments contain AECOM confidential information that may be =
    proprietary or privileged. If you receive this message in error or are not =
    not retain, distribute, disclose or use any of this information and you sh=
    ould destroy the e-mail and any attachments or copies.
    –_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71D30DUSDEN3EXMB002An_–
    #9140
    Thanks Mark that did it!
