Welcome to the RAS Solution Forums HEC-RAS Help Simulation Error – Same statio/elevation point twice?!
Viewing 15 posts - 1 through 15 (of 17 total)
  • #5357
    Kampies
    When running my simulation the following message pops up and stops the simulation:
    “Steady Flow Simulation Version 4.1.0 Jan 2010
    The GUI sent the same station/elevation point twice.
    -31.23 4314.86
    at river station 94.1 in reach Mamelodi East
    Review your data at this location for completeness and consistency”
    Now, I went through all my x-sections, Culvert/roadway at this point but I do not see the value -31.23 or 4314.86 as per the message above.
    For background purposes, it is a stream flow model with 3 x culvert/roadways, moddeling 20,50 & 100 year flows.
    Can anyone point me into the correct direction in order to resolve my problem?
    #8557
    Keymaster
    Try looking at the internal bridge cross sections, see if you see something there. Or you can open the geometry file in a text editor (Wordpad, Notepad, etc.) and then search for the station/elevation points listed in the error message. That might show you where the offense is taking place.
    If that doesn’t work, try deleting 94.1 and re-entering it.
    Good Luck-
    @RASModel
    #8558
    I’ve got de same kind of error with one bridge in my simulation.
    I use Hec-Ras 4.1.0
    The internal bridge cross section is ok. Same thing with the geometry file.
    If I delete the bridge my simulation is running ok but if I re-enter it I’ve got the same error.
    If I delete the two cross section each side of the bridge and re-center de bridge in the new internal cross section, my simulation is running ok but if I want to re-enter these sections, the error strike back.
    Any help ?
    #8571
    just increase the stations of the bridge/culvert manually. I have solved the same problem with this.
    #8559
    you should increase the deck roadway station just 1 mm. by this your problem will be solved.
    janset
    #8560
    Kampies
    Return-path:
    Envelope-to: ml-node+s1091112n559h10@n5.nabble.com
    Delivery-date: Tue, 04 Feb 2014 22:25:20 -0800
    Received: from mail26.mimecast.co.za ([41.74.197.26])
    by sam.nabble.com with esmtp (Exim 4.72)
    (envelope-from )
    id 1WAvvD-0000nX-Uy
    for ml-node+s1091112n559h10@n5.nabble.com; Tue, 04 Feb 2014 22:25:20 -0800
    Received: from zaptcsv001.smecnet.com
    (197.231.160-163.reverse.CMCNETWORKS.NET [197.231.160.163]) (Using TLS) by
    mail26.mimecast.co.za; Wed, 05 Feb 2014 08:25:16 +0200
    Received: from ZAPTEXV001.smecnet.com ([::1]) by zaptcsv001.smecnet.com
    ([::1]) with mapi id 14.03.0174.001; Wed, 5 Feb 2014 08:25:15 +0200
    To: “janset [via HEC-RAS Bloggery Forum]”
    Subject: RE: Simulation Error – Same statio/elevation point twice?!
    Thread-Topic: Simulation Error – Same statio/elevation point twice?!
    Thread-Index: AQHOqxkdu1Jj0CHEnku0lx838+QcR5ql4DgAgAFAH1A=
    Date: Wed, 5 Feb 2014 06:25:14 +0000
    Message-ID: <34465A3786C675488C07864DBA206EC93023698E@ZAPTEXV001.smecnet.com>
    References: <1378363875625-313.post@n5.nabble.com>
    <1378482340418-320.post@n5.nabble.com> <1391520071742-559.post@n5.nabble.com>
    In-Reply-To: <1391520071742-559.post@n5.nabble.com>
    Accept-Language: en-GB, en-ZA, en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    x-originating-ip: [196.36.233.95]
    MIME-Version: 1.0
    X-MC-Unique: 114020508251603902
    boundary=”_000_34465A3786C675488C07864DBA206EC93023698EZAPTEXV001smecn_”
    X-SA-Exim-Connect-IP: 41.74.197.26
    X-SA-Exim-Mail-From: juan.kampman@smec.com
    X-SA-Exim-Scanned: No (on sam.nabble.com); SAEximRunCond expanded to false
    –_000_34465A3786C675488C07864DBA206EC93023698EZAPTEXV001smecn_
    Content-Type: text/plain; charset=WINDOWS-1252
    Thanks Janset
    I did the same and worked well.
    Regards,
    Juan
    From: janset [via HEC-RAS Bloggery Forum] [mailto:ml-node+s1091112n559h10@n=
    5.nabble.com]
    Sent: 04 February 2014 03:21 PM
    To: Kampman, Juan
    Subject: Re: Simulation Error – Same statio/elevation point twice?!
    you should increase the deck roadway station just 1 mm. by this your proble=
    m will be solved.
    janset
    low:
    http://hec-ras-bloggery-forum.1091112.n5.nabble.com/Simulation-Error-Same-s=
    tatio-elevation-point-twice-tp313p559.html
    To unsubscribe from Simulation Error – Same statio/elevation point twice?!,=
    click here<http://hec-ras-bloggery-forum.1091112.n5.nabble.com/template/Na=
    mlServlet.jtp?macro=3Dunsubscribe_by_code&node=3D313&code=3DanVhbi5rYW1wbWF=
    uQHNtZWMuY29tfDMxM3wxNDk1MDQ4ODYw>.
    NAML<http://hec-ras-bloggery-forum.1091112.n5.nabble.com/template/NamlServl=
    et.jtp?macro=3Dmacro_viewer&id=3Dinstant_html%21nabble%3Aemail.naml&base=3D=
    ace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNa=
    mespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.Nabb=
    leNamespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.=
    NabbleNamespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.templ=
    ate.NabbleNamespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.t=
    emplate.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=
    =3Dnotify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail=
    .naml-send_instant_email%21nabble%3Aemail.naml>
    _____________________________________________________________________
    This e-mail has been scanned for viruses by Symantec.Cloud.
    Content-Type: text/html; charset=WINDOWS-1252
    Thanks Janset<= /span>
     <= /p>
    I did the same and worked=
    well.
     <= /p>
    Regards,
    Juan
     <= /p>
    From: janset [via HEC-RAS Bloggery Forum] [mailto:ml-node&#=
    43;s1091112n559h10@n5.nabble.com]
    To: Kampman, Juan
    Subject: Re: Simulation Error – Same statio/elevation point twice?!<= o:p>
    you should increase t=
    janset
    If you reply to this ema=
    il, your message will be added to the discussion below:
    http://hec-ras-bloggery-forum.1091112.n5.nabble=
    .com/Simulation-Error-Same-statio-elevation-point-twice-tp313p559.html
    click here.
    NAML
    –_000_34465A3786C675488C07864DBA206EC93023698EZAPTEXV001smecn_–
    #8562
    hec-pole84
    Hello Janset.
    I did not understand what you mean when you say to increase “deck roadway station” , could you display me here with a pic where did you made this correction ?
    Thank you
    Hec-pole84
    #8563
    santiago
    Hello Janset & hec-pole84.
    I have the same problem, could you display me here with a pic where did you made this correction ?
    Thank you
    santiago
    #8564
    Hello Hello Janset, hec-pole84 and Santiago.
    Go to Geometry data editor > Edit and/or create bridges and culverts > Deck/Roadway > In the table add 0.001mm in the fist column.
    That’s it!
    #8570
    r5128
    Thank you
    #8561
    r5128
    I have the same problem, could you display me here with a pic where did you made this correction ? and tell me why
    Thank you
    #8565
    r5128
    Thank you
    #8566
    Hello r5128 !
    It’s perhaps too late but I encountered the same issue and it was a matter of piers.
    One pier (or more) were overlapping with the deck/road or each other. Try this way !
    Good luck
    #8567
    r5128
    Return-Path:
    by sloti1d2t14 (Cyrus 3.1.5-925-g644bf8c-fmstable-20190228v5) with LMTPA;
    Sun, 03 Mar 2019 22:14:22 -0500
    X-Cyrus-Session-Id: sloti1d2t14-1551669262-938312-2-3614643301682111877
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 1.9
    X-Spam-hits: FREEMAIL_ENVFROM_END_DIGIT 0.25, FREEMAIL_FROM 0.001,
    FROM_EXCESS_BASE64 0.105, HTML_MESSAGE 0.001, ME_ZS_CLEAN -0.001,
    PLING_QUERY 0.279, RCVD_IN_DNSWL_NONE -0.0001, SPF_PASS -0.001,
    URI_HEX 1.313, LANGUAGES en, BAYES_USED none, SA_VERSION 3.4.2
    X-Spam-source: IP=’209.85.166.175′, Host=’mail-it1-f175.google.com’, Country=’US’,
    X-Spam-charsets: from=’UTF-8′, plain=’UTF-8′, html=’UTF-8′
    X-Resolved-to: ml+s1091112n7267h46@n5.nabble.com
    X-Delivered-to: ml+s1091112n7267h46@n5.nabble.com
    X-Mail-from: r51282001@gmail.com
    Received: from mx6 ([10.202.2.205])
    by compute1.internal (LMTPProxy); Sun, 03 Mar 2019 22:14:22 -0500
    Received: from mx6.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id C70674256B
    for ; Sun, 3 Mar 2019 22:14:21 -0500 (EST)
    by mx6.messagingengine.com (Authentication Milter) with ESMTP
    id 40C08E744EC;
    1551669261; b=TTycafXnfS0RxLPTGQAuPluW8Y+Fpq6NHW6hZ5qdkkzSxbZRhM
    twxcY9FR4TzvYqlWWF3DLkfnNdJANLGclwgVZkuo+cLIapVdZdMfKbhkowBfcR+z
    fHX/WPFQtq6GlThZF+CpxTNKAEJiN+k7qQ3++pHMKlSXLYTCYO3nNre+GpXMmnj5
    RgKFGgUP1Q/j6IJ8dgdhqz4G3jLoGCPpPM4kjdoOWF4mboacwDa+sE46a3oEV2jT
    UQga+D7b++Dwys3p+EyY079GCtcAFTX0oVEAEjdtKMt1NqpBRm0dLeFRmyWMyu+w
    dZZzXme/vtzI4yQfHzLod5mYqarEnYxz1cJg==
    :date:message-id:subject:to:content-type; s=fm2; t=1551669261;
    bh=wclnsK7ud4zVkZnePyocrHLetiKuT39Z/guMNGrEYTs=; b=WMU6PsMcYuGe
    D8tt4ysn/83eYJYvv5Mr3odH9GGWWZsWyPLQHcTe7W7RPJRgaeW/ZtF9SQ77PiLb
    Do2feV+uXsF91B7ZtsCjPwAE0ek/AnW9x9Eq3cwIUZDGKxGwtuBEuYJiJGG9Shjj
    ntNbAaSYRyUTGcZkBDggR3SONfnA4GiqrEQhxdy26L0/fxp2C3VWR+RPnVOsT8Cy
    wfIwihFGVQFaSNgpW9K96XZ7w9+Jt2WGYHR/zECC82e6KV1lZ6XYh5fERYbhMek5
    I72GY1ecegPkxLJupN+/zxvxkpDVxsp8S4IuvqSG5aNu5E+2X7pnWrmNdeWX+i5B
    66yM41OSbw==
    ARC-Authentication-Results: i=1; mx6.messagingengine.com; arc=none (no signatures found);
    header.i=@gmail.com header.b=m39dqY0H header.a=rsa-sha256
    header.from=gmail.com;
    iprev=pass smtp.remote-ip=209.85.166.175 (mail-it1-f175.google.com);
    spf=pass smtp.mailfrom=r51282001@gmail.com
    smtp.helo=mail-it1-f175.google.com;
    header.i=@1e100.net header.b=aLd3uRjA;
    x-ptr=pass smtp.helo=mail-it1-f175.google.com
    policy.ptr=mail-it1-f175.google.com;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-vs=clean score=0 state=0;
    x-zs=clean
    Authentication-Results: mx6.messagingengine.com;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-zs=clean
    xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0z
    MTMmY29kZT1jalV4TWpneU1EQXhRR2R0WVdsc0xtTnZiWHd6TVROOE9UYzNNemN4TnpZNA
    X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedutddrfedtgdehhecutefuodetggdotefrodftvf
    curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgdpuffr
    tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecunecujfgurhepgghfjgfhff
    fkuffvtgesrgdtreertddtjeenucfhrhhomhepnjjnuceorhehuddvkedvtddtudesghhm
    rghilhdrtghomheqnecuffhomhgrihhnpehnrggssghlvgdrtghomhenucfkphepvddtle
    drkeehrdduieeirddujeehnecurfgrrhgrmhepihhnvghtpedvtdelrdekhedrudeiiedr
    udejhedphhgvlhhopehmrghilhdqihhtuddqfhdujeehrdhgohhoghhlvgdrtghomhdpmh
    grihhlfhhrohhmpeeorhehuddvkedvtddtudesghhmrghilhdrtghomhequcfukfgkgfep
    jeejleefnecuvehluhhsthgvrhfuihiivgeptd
    X-ME-VSScore: 0
    X-ME-VSCategory: clean
    X-ME-ZSResult: clean
    Received-SPF: pass
    (gmail.com … _spf.google.com: Sender is authorized to use ‘r51282001@gmail.com’ in ‘mfrom’ identity (mechanism ‘include:_netblocks.google.com’ matched))
    receiver=mx6.messagingengine.com;
    identity=mailfrom;
    envelope-from=”r51282001@gmail.com”;
    client-ip=209.85.166.175
    Received: from mail-it1-f175.google.com (mail-it1-f175.google.com [209.85.166.175])
    by mx6.messagingengine.com (Postfix) with ESMTPS
    Received: by mail-it1-f175.google.com with SMTP id z124so5493478itc.2
    for ; Sun, 03 Mar 2019 19:14:21 -0800 (PST)
    d=gmail.com; s=20161025;
    b=m39dqY0Hlre0PSeozXdjyqC0shFLirDzMoZ1rR6dH4nhia0EYxrj5HRP2VRO/Eh43K
    bHXLs5gI2ihKu5I5zsz8mDHpvos4ZaXwDqHH9h+vd6xyh7llTZrAqBfflbjj6gijycgg
    Mb05kDVEvOAtaigsE3Ky94YSNlnrnzR7sfq5w+zWjPnA8uYaAgXAhzyhK9bfctwMjw8y
    Th2AsOoHExqf9gyLCr0+rYGQtKhYMVEW/SQ3lDm+xs3LDiO/ylZr+0/1TH/C+kBNQynX
    xGtpVeUJrKckdpeb32aTGo3DOoeX6s/hxKlw/B6QxFNFpiNN0mFCYbuAqVlo5vl0xO/z
    0r6A==
    d=1e100.net; s=20161025;
    b=aLd3uRjA4VJlOP04rshJdLEsJ3f+7GPjTvvbtrI0AHbGkd8yzD5NVu5e/fRYRtAjCS
    Cgw/j8I1VBux90uaOwv5BClrO1rs4Dg5AW/Pqh7M0XQFxzvhT3papLu2yFn8igvrubG6
    SR6gJQLOLePY+xAEfVdMmphcYWvhADelzbn2RbL0ewBOdlzpIQ9oVvt/XHqWX8n3pXmp
    jA2VObsnQE0+Ndrzv0FkWngsd1Rec2lNGZoZByQhoqXQBBr1O4KpTINgnIRsOBmnhA/u
    FBzG/5RJxpFRhpCPn1pS3SWmEKqUEkXMA9Hwl9B+SFAtXExPxlGG+DbX5EVBnHyGkaPX
    vjaA==
    X-Gm-Message-State: APjAAAUbOtz67RLK3q6upTxqEpnNRlkOCnuvqe3vYIPF/6pexHEc5BCD
    3gchrpiZAO7g664j2v06NNmlOQ3z0ogLMZvAXePZpT4z
    X-Google-Smtp-Source: APXvYqzXD7EN2+dadT/1PP21bsLD3YPL8gjXWWmVxwwqPMYZ6J0DJfKVoSb/eIb6iC5+3sTtOkginwYXa2ScUqu0C5o=
    X-Received: by 2002:a02:3c07:: with SMTP id m7mr9717248jaa.26.1551669259457;
    Sun, 03 Mar 2019 19:14:19 -0800 (PST)
    MIME-Version: 1.0
    References: <1378363875625-313.post@n5.nabble.com> <1378482340418-320.post@n5.nabble.com>
    <1391520071742-559.post@n5.nabble.com> <1392737487286-573.post@n5.nabble.com>
    <1394335141282-595.post@n5.nabble.com> <1394567897511-598.post@n5.nabble.com>
    <1515134262952-5072.post@n5.nabble.com> <1551426404410-7267.post@n5.nabble.com>
    In-Reply-To: <1551426404410-7267.post@n5.nabble.com>
    Date: Mon, 4 Mar 2019 11:14:08 +0800
    Message-ID:
    To: “Gnut [via HEC-RAS Help]”
    Content-Type: multipart/alternative; boundary=”00000000000004da1b05833c2703″
    –00000000000004da1b05833c2703
    Thanks Gnut: =E5=95=8F=E9=A1=8C=E5=B7=B2=E7=B6=93=E8=A7=A3=E6=B1=BA=E4=BA=
    =86
    Gnut [via HEC-RAS Help] =E6=96=BC 2019=
    =E5=B9=B43=E6=9C=881=E6=97=A5 =E9=80=B1=E4=BA=94
    =E4=B8=8B=E5=8D=883:51=E5=AF=AB=E9=81=93=EF=BC=9A
    > Hello r5128 !
    > It’s perhaps too late but I encountered the same issue and it was a matte=
    r
    > of piers.
    > this way !
    > Good luck
    > below:
    > http://hec-ras-help.1091112.n5.nabble.com/Simulation-Error-Same-statio-el=
    evation-point-twice-tp313p7267.html
    > twice?!, click here
    =3Dunsubscribe_by_code&node=3D313&code=3DcjUxMjgyMDAxQGdtYWlsLmNvbXwzMTN8OT=
    c3MzcxNzY4>
    > NAML
    leNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_sub=
    scribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_in=
    Thanks Gnut:
    =E5=95=8F=E9=A1=8C=E5=B7=B2=E7=B6=93=E8=A7=A3=E6=B1=BA=E4=BA=86=
    Gnut [via HEC-RAS Help] <ml+s1091112n7267h46@n5.nabble.com> =E6=96=BC=
    2019=E5=B9=B43=E6=9C=881=E6=97=A5 =E9=80=B1=E4=BA=94 =E4=B8=8B=E5=8D=883:5=
    le=3D"margin:0px 0px 0px 0.8ex;border-left:1px solid rgb(204,204,204);paddi= ng-left:1ex">
    Hello r5128 !
    It's perhaps too late but I encountered the same issue and it was a=
    matter of piers.
    One pier (or more) were overlapping with the deck/road or each other. T=
    ry this way !
    Good luck
    =09
    =09
    =09
    http://he=
    c-ras-help.1091112.n5.nabble.com/Simulation-Error-Same-statio-elevation-poi=
    =09
    To unsubscribe from Simulation Error – Same statio/elevation point twice?=
    !, click here.
    NAML
    –00000000000004da1b05833c2703–
    #8568
    r5128
    Return-Path:
    Sun, 03 Mar 2019 22:17:22 -0500
    X-Cyrus-Session-Id: sloti1d2t14-1551669442-978444-2-6326397812272624966
    X-Spam-score: 1.9
    URI_HEX 1.313, LANGUAGES unknown, BAYES_USED none, SA_VERSION 3.4.2
    X-Spam-source: IP=’209.85.166.176′, Host=’mail-it1-f176.google.com’, Country=’US’,
    Received: from mx3 ([10.202.2.202])
    by compute1.internal (LMTPProxy); Sun, 03 Mar 2019 22:17:22 -0500
    Received: from mx3.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id 84C4D46077
    for ; Sun, 3 Mar 2019 22:17:21 -0500 (EST)
    by mx3.messagingengine.com (Authentication Milter) with ESMTP
    id 16363FF2D22;
    1551669441; b=5Y8SjF1PxVeNCbrUtbr+cBvJ7I1TbGvAeE/95Sj1RmKQWN9F9L
    DukRgnE1HdoeZJojZ0DyTV/GFQV8SRsMFKtQGUh7cP0cra6NZGWL5/yyediXQRhz
    RXS006tX8GrDvCghaoFG0AH4bLR8CU7wUfXwGwEQRXo/IBXIWCALEVFISiwZNQoh
    jOVHAr8ZqqE2v6j0Z/RkA5w+CLngoCj1ct5lFsiHOmRVloeTHxje6dZwHmhEe3pn
    AOYgO1fJ8iNaWUMTKcLGPlJcJk0UwWHvdJyKuP96xcFjNb+mLQe6uqRVbC0LIbNy
    xIKiHtRUfw+4ADXxjEdlwEcHLTOeEQFgKMUg==
    :date:message-id:subject:to:content-type; s=fm2; t=1551669441;
    bh=7dXDEWSHAvXN7+XSsBj9X+vryWLUQ3mvXAAK2rJFDDY=; b=qyz7Qu4kfMrL
    sWFTcb6gCglVtqIjCl8XtcPGPb3Rth4plfoUqY4abPL0RRJudi+A8kl1rTsam+/8
    7ZcDD516ChuxCp6ZMjzvMq0MSZnd5SLBqeVF+6gnexP0Dsjg2dW/4T35pJ1/9itm
    YI5S7MfnbZAGZI+V14w87AJhulBfcxOHDjZByLkmPdN1xUMHBf/YaVlhzRewJzCJ
    +uVVq6CCArXoU18w/UHB62sqilLnk45Xe3QL9kt+YOMnLlKLwzjI/xvWXxYYiTLh
    AeZLl04CdcIBks85rVlalFGRZF0QYtVsqgIyv0Mz2QFGZcvUkDlzt4gAXs9w9Y5+
    zPO+8CEnsw==
    ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
    header.i=@gmail.com header.b=rXL5UBBI header.a=rsa-sha256
    iprev=pass smtp.remote-ip=209.85.166.176 (mail-it1-f176.google.com);
    smtp.helo=mail-it1-f176.google.com;
    header.i=@1e100.net header.b=IjODPQOt;
    x-ptr=pass smtp.helo=mail-it1-f176.google.com
    policy.ptr=mail-it1-f176.google.com;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-zs=clean
    Authentication-Results: mx3.messagingengine.com;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-zs=clean
    drkeehrdduieeirddujeeinecurfgrrhgrmhepihhnvghtpedvtdelrdekhedrudeiiedr
    udejiedphhgvlhhopehmrghilhdqihhtuddqfhdujeeirdhgohhoghhlvgdrtghomhdpmh
    uddvtdeludenucevlhhushhtvghrufhiiigvpedt
    X-ME-VSScore: 0
    Received-SPF: pass
    receiver=mx3.messagingengine.com;
    identity=mailfrom;
    client-ip=209.85.166.176
    Received: from mail-it1-f176.google.com (mail-it1-f176.google.com [209.85.166.176])
    by mx3.messagingengine.com (Postfix) with ESMTPS
    Received: by mail-it1-f176.google.com with SMTP id v2so5295225ith.3
    for ; Sun, 03 Mar 2019 19:17:21 -0800 (PST)
    b=rXL5UBBIExGh+FRk20QMnieTTMBw9RvgzGgu4taTcRnXxJrzm3J5zn5K0QygZoS8Hn
    2aQocLN0y/bD8R1WwgjqjYKfCRh7ugRNjmTBvGnNafKxoPpZ3t5xdfiFawT54j37v4sh
    rwwVHibdq80q/yigNhh5w/yOX9ODUwUFcxGlfWWgTwjR01W6nUVfrWybndefXJiedLLl
    sdFnROD2KcrGlcFiapl6ouN61YbmLhrfdFY6/6qAx/hiKCu2kQ2YF7ZNAmkUNQPKpEPr
    7EwTbi2ejfste2MCgtb1baMBuO4cd1HEe1QYumB6AT4T1Eny1FJFoTkaj8CGQDgAs29F
    j1vg==
    b=IjODPQOtjUw+y3Ef3ir7pkb2XujO7dqxvUSuT8UkWkYGYlrQrwWuNoLcWZe1TBZAME
    NvTjHeO8wE80h0lLDc/toRuyHqQ7Duxv4bTEgixXovA0J3XLIeLuMt0WDstUrD3qdCA0
    bDrkr/zxT3Fodq8FGNDKiDvoz7oWsOPLMMtO+d8IReRH9C0MGTqWOkvp1MqzNkkRQhah
    7F/8qKiFWasYNQ8RXi3i/U8lW6wtY6NaQCIya6iymWWig6jFuT/o/GC5MZN4BExGMfhb
    shgKKwgMsGZKfBjeS/y/EgT+/zxjqQRPiI04IgiwedCzG6FAO6HkBtqJOrbHZJsF5rrs
    1oXw==
    X-Gm-Message-State: AHQUAuZKyeQHielAg5V3Va2vaLSrXGoXzUDlXlYt0CBVzDDrITflFWdP
    4GTEQ5XLh7so0VGm2AogCR3l9rGB6lLJaQOtU8T5xg==
    X-Google-Smtp-Source: AHgI3Ia3WU76Z9zq4kT/mUh1pnTISraN1X1omSN68FZxahvV6xOnJqWZIm1eOhvbjraAdPJlEoVRuvRx6ABer/Ywlpc=
    X-Received: by 2002:a24:e50b:: with SMTP id g11mr9752799iti.14.1551669439151;
    Sun, 03 Mar 2019 19:17:19 -0800 (PST)
    MIME-Version: 1.0
    In-Reply-To:
    Date: Mon, 4 Mar 2019 11:17:08 +0800
    Message-ID:
    Content-Type: multipart/alternative; boundary=”000000000000bac39005833c31db”
    –000000000000bac39005833c31db
    ICDllY/poYzlt7LntpPop6PmsbrkuoYNCg0K6LGq5b+XIDxyNTEyODIwMDFAZ21haWwuY29tPiDm
    lrwgMjAxOeW5tDPmnIg05pelIOmAseS4gCDkuIrljYgxMToxNOWvq+mBk++8mg0KDQo+IFRoYW5r
    cyBHbnV0OiDllY/poYzlt7LntpPop6PmsbrkuoYNCj4NCj4gR251dCBbdmlhIEhFQy1SQVMgSGVs
    cF0gPG1sK3MxMDkxMTEybjcyNjdoNDZAbjUubmFiYmxlLmNvbT4g5pa8IDIwMTnlubQz5pyIMeaX
    pQ0KPiDpgLHkupQg5LiL5Y2IMzo1MeWvq+mBk++8mg0KPg0KPj4g5L2g5aW9cjUxMjjvvIENCj4+
    IOmAmeWPr+iDveeCuuaZguW3suaZmu+8jOS9huaIkemBh+WIsOS6huWQjOaoo+eahOWVj+mhjO+8
    jOmAmeaYr+S4gOWAi+eivOmgreWVj+mhjOOAgg0KPj4g5LiA5YCL77yI5oiW5pu05aSa77yJ56K8
    6aCt6IiH55Sy5p2/L+mBk+i3r+aIluW9vOatpOmHjeeWiuOAguippuippumAmeeoruaWueW8j++8
    gQ0KPj4g56Wd5aW96YGLDQo+Pg0KPj4gLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tDQo+
    PiDlpoLmnpzmgqjlm57lpI3mraTpm7vlrZDpg7Xku7bvvIzmgqjnmoTpg7Xku7blsIfooqvmt7vl
    iqDliLDku6XkuIvoqI7oq5bkuK3vvJoNCj4+IGh0dHA6Ly9oZWMtcmFzLWhlbHAuMTA5MTExMi4g
    bjUubmFiYmxlLmNvbS9TaW11bGF0aW9uLSBFcnJvci1TYW1lLXN0YXRpby1lbGV2YXRpb24tDQo+
    PiBwb2ludC10d2ljZS10cDMxM3A3MjY3Lmh0bWwNCj4+IDxodHRwOi8vaGVjLXJhcy1oZWxwLjEw
    OTExMTIubjUubmFiYmxlLmNvbS9TaW11bGF0aW9uLUVycm9yLVNhbWUtc3RhdGlvLWVsZXZhdGlv
    bi1wb2ludC10d2ljZS10cDMxM3A3MjY3Lmh0bWw+DQo+PiDopoHlj5bmtojoqILplrHmqKHmk6zp
    jK/oqqQgLSDlhanmrKHnm7jlkIznmoTnq5npu54v6auY56iL6bue77yf77yB77yM6KuL5Zau5pOK
    5q2k6JmVDQo+PiA8aHR0cDovL2hlYy1yYXMtaGVscC4xMDkxMTEyLm41Lm5hYmJsZS5jb20vdGVt
    cGxhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0zMTMm
    Y29kZT1jalV4TWpneU1EQXhRR2R0WVdsc0xtTnZiWHd6TVROOE9UYzNNemN4TnpZND4NCj4+IOOA
    gg0KPj4gTmFtbOeahA0KPj4gPGh0dHA6Ly9oZWMtcmFzLWhlbHAuMTA5MTExMi5uNS5uYWJibGUu
    Y29tL3RlbXBsYXRlL05hbWxTZXJ2bGV0Lmp0cD9tYWNybz1tYWNyb192aWV3ZXImaWQ9aW5zdGFu
    dF9odG1sJTIxbmFiYmxlJTNBZW1haWwubmFtbCZiYXNlPW5hYmJsZS5uYW1sLm5hbWVzcGFjZXMu
    QmFzaWNOYW1lc3BhY2UtbmFiYmxlLnZpZXcud2ViLnRlbXBsYXRlLk5hYmJsZU5hbWVzcGFjZS1u
    YWJibGUubmFtbC5uYW1lc3BhY2VzLkJhc2ljTmFtZXNwYWNlLW5hYmJsZS52aWV3LndlYi50ZW1w
    bGF0ZS5OYWJibGVOYW1lc3BhY2UtbmFiYmxlLm5hbWwubmFtZXNwYWNlcy5CYXNpY05hbWVzcGFj
    ZS1uYWJibGUudmlldy53ZWIudGVtcGxhdGUuTmFiYmxlTmFtZXNwYWNlLW5hYmJsZS5uYW1sLm5h
    bWVzcGFjZXMuQmFzaWNOYW1lc3BhY2UtbmFiYmxlLnZpZXcud2ViLnRlbXBsYXRlLk5hYmJsZU5h
    bWVzcGFjZS1uYWJibGUubmFtbC5uYW1lc3BhY2VzLkJhc2ljTmFtZXNwYWNlLW5hYmJsZS52aWV3
    LndlYi50ZW1wbGF0ZS5OYWJibGVOYW1lc3BhY2UtbmFiYmxlLm5hbWwubmFtZXNwYWNlcy5CYXNp
    Y05hbWVzcGFjZS1uYWJibGUudmlldy53ZWIudGVtcGxhdGUuTmFiYmxlTmFtZXNwYWNlLW5hYmJs
    ZS52aWV3LndlYi50ZW1wbGF0ZS5Ob2RlTmFtZXNwYWNlJmJyZWFkY3J1bWJzPW5vdGlmeV9zdWJz
    Y3JpYmVycyUyMW5hYmJsZSUzQWVtYWlsLm5hbWwtaW5zdGFudF9lbWFpbHMlMjFuYWJibGUlM0Fl
    bWFpbC5uYW1sLXNlbmRfaW5zdGFudF9lbWFpbCUyMW5hYmJsZSUzQWVtYWlsLm5hbWw+DQo+Pg0K
    Pg0K
    =C2=A0
    =C2=A0=C2=A0
    =E8=B1=AA=E5=BF=97 <r51282001@gmail.com> =E6=96=BC 2019=E5=
    =B9=B43=E6=9C=884=E6=97=A5 =E9=80=B1=E4=B8=80 =E4=B8=8A=E5=8D=8811:14=E5=AF=
    argin:0px 0px 0px 0.8ex;border-left:1px solid rgb(204,204,204);padding-left= :1ex">
    Thanks Gnut:
    Gnut [via HEC-RAS Help] <<= font style=3D"vertical-align:inherit">ml+s1091112n7267h46@n5.nabble.com&g=
    t; =E6=96=BC 2019=E5=B9=B43=E6=9C=881=E6=97=A5 =E9=80=B1=E4=BA=94 =E4=B8=8B=
    class=3D"gmail_quote" style=3D"margin:0px 0px 0px 0.8ex;border-left:1px so= lid rgb(204,204,204);padding-left:1ex">
    =E4=BD=A0=E5=A5=BDr5128=EF=BC=81
    =E9=80=99=E5=8F=AF=E8=83=BD=E7=82=BA=E6=99=82=E5=B7=B2=
    =E6=99=9A=EF=BC=8C=E4=BD=86=E6=88=91=E9=81=87=E5=88=B0=E4=BA=86=E5=90=8C=E6=
    =A8=A3=E7=9A=84=E5=95=8F=E9=A1=8C=EF=BC=8C=E9=80=99=E6=98=AF=E4=B8=80=E5=80=
    =8B=E7=A2=BC=E9=A0=AD=E5=95=8F=E9=A1=8C=E3=80=82
    =E4=B8=80=E5=80=8B=EF=BC=88=E6=88=96=E6=9B=B4=E5=A4=9A=
    =EF=BC=89=E7=A2=BC=E9=A0=AD=E8=88=87=E7=94=B2=E6=9D=BF/=E9=81=93=E8=B7=AF=
    =E6=88=96=E5=BD=BC=E6=AD=A4=E9=87=8D=E7=96=8A=E3=80=82
    =E8=A9=A6=E8=A9=A6=E9=80=99=E7=A8=AE=E6=96=B9=E5=
    =BC=8F=EF=BC=81
    =E7=A5=9D=E5=A5=BD=E9=81=8B
    =09
    =09
    =09
    =E5=A6=82=E6=9E=9C=E6=82=A8=E5=9B=9E=
    =E5=A4=8D=E6=AD=A4=E9=9B=BB=E5=AD=90=E9=83=B5=E4=BB=B6=EF=BC=8C=E6=82=A8=E7=
    =9A=84=E9=83=B5=E4=BB=B6=E5=B0=87=E8=A2=AB=E6=B7=BB=E5=8A=A0=E5=88=B0=E4=BB=
    =A5=E4=B8=8B=E8=A8=8E=E8=AB=96=E4=B8=AD=EF=BC=9A
    http:/=
    n5.nabble.com/Simulation- Error-Same-statio-elevation- point-twice-tp313p726=
    7.html
    =09
    =E8=A6=81=E5=8F=96=E6=B6=88=E8=A8=82=E9=96=B1=E6=A8=A1=E6=93=AC=E9=8C=AF=
    =E8=AA=A4 – =E5=85=A9=E6=AC=A1=E7=9B=B8=E5=90=8C=E7=9A=84=E7=AB=99=E9=BB=9E=
    /=E9=AB=98=E7=A8=8B=E9=BB=9E=EF=BC=9F=EF=BC=81=EF=BC=8C
    =E8=AB=8B=E5=96=AE=E6=93=8A=E6=
    =AD=A4=E8=99=95
    =E3=80=82
    Naml=E7=9A=84
    –000000000000bac39005833c31db–
