Welcome to the RAS Solution Forums HEC-RAS Help Significant Flow Depth
  • #6115
    JoseD
    I am modeling a simple 300ft wide terrain about 1,5000 long (normal depth downstream BC) with a (Upstream hydro graph BC) 500 cfs design flow Tp 45 minutes (Everything else is pretty much default settings). However, my flow depth is 15 feet. I reduced the default “n” and got a depth of 10 feet.
    The terrain is mostly flat with a shallow slope of about 1%.
    Any idea what could make the water pond so high? Or any idea on a process to discover the issue will be greatly appreciated.
    #9945
    Have you tried varying your normal depth value while holding the Manning’s value constant?
