  • #5355
    voja
    Hello everybody. I use siam model, but I don’t know how to solve this problem, if I try to compute model in siam, program give me message- modMain.Main-unknown case in Select Case mCommandLine.Count, after that if I clic ok and compute button program give me message- Run-time error ’76’ path not found and stop function.
    Who could help me to solve this…
    Thanks.
    #8554
    Keymaster
    That’s a bug. You should send it to HEC using their bug report. http://www.hec.usace.army.mil/software/hec-ras/bug_report.aspx
    In the meantime, double check that you’ve entered in all of the required data, the data makes sense, and that you have your Windows International settings set to English (United States).
    Good luck.
