Welcome to the RAS Solution Forums HEC-RAS Help setting up Hot Start file
  • #6110
    Joe S.
    Are there any past forum discussion on setting up a hot start file?
    I did not find anything in forum. And I did a quick search of various User Manuals, without any documentation found.
    Under Unsteady Flow Analysis, set output control options, there is the RESTART FILE tabs. Do I run this hotstart for 1 hour, to establish my initial conditions. Then do I COMPUTE for the exact same time duration?
    ____________________________________
    errors:
    Performing Unsteady Flow Simulation HEC-RAS 5.0.1 April 2016
    **** ERROR: Solution Solver Failed ****
    Unstable for Initial Iteration at 16MAY2016 0100
    Writing Results to DSS
    Error with program: RasDSSWriter64.exe Exit Code = 1
    #9936
    PaoloP
    Joe,
    it is not clear to me.
    Did you create an hot-start file and the model crash when you use this hot-start or the model crash when you are running the model to create the hot-start?
    Paolo
    #9937
    Joe S.
    the error happens without a hot start, and even after I tried to make a hot start file. I might not be creating the hot start correctly.
    #9938
    PaoloP
    Joe,
    usually the hot-start is used to continue previous simulation or to create the initial condition when the model is complex or unstable for low discharge using the steady state initial condition.
    In the last case you have to run a simulation starting with initial conditions those are stable and decrease the flow up to the discharge you want to use as initial condition for your simulation and than save the hot-start. Obviously the simulation must be stable, if not you have to change something in the geometry.
    Paolo
