• This topic has 1 reply, 792 voices, and was last updated 9 years ago by Anonymous.
  • #8188
    I’m having some difficulty changing plans with the RAS controller using python. I’m attempting to set the current plan using both Plan_SetCurrent() and PlanOutput_SetCurrent(). When I run PlanOutput_IsCurrent(), the message returned states that RAS is looking at the proper plan and output file. I’m then getting a list of profiles using Output_GetProfiles(), which works fine for the first plan.
    The trouble is when I attempt to switch to a different plan. PlanOutput_IsCurrent() responds with the information for the second plan, but Output_GetProfiles() still returns the profiles for the first plan. The impression I’m getting is that Plan*_SetCurrent() can only be used once to the set the plan and that repeated call after setting an intial call are (partially) ignored. Has anyone else experienced this?
    Also, is there a way to determine the current plan? CurrentPlanFile() returns the file, but is there anyway to get the current plan name, besides grabbing it from the plan file?
    Mike
    #13519
    I’ve narrowed this down a bit, the plan appears to be getting “locked in place” by a call to Output_GetProfiles(). As long as I don’t call OGP(), it appears I can change plans all I like, but some how calling OGP() prevents me from successfully changing plans. Very weird. Also, “Breaking the HEC-RAS code” states that the first value passed to OGP() used to return the river ID, which doesn’t make any sense when asking for a list of profiles. Thoughts Chris G?
