Welcome to the RAS Solution Forums HEC-RAS Help Separate boundary condition
  • #6229
    igorce
    Please for your opinion, comments and guidance on the issue:
    1. Why are getting an unrealistic hydraulics?
    2. Can be placed boundary conditions in any section (in that section which i want)
    Please see the picture and i wait comment!
    Thanks in advance
    #10127
    Are you getting any warnings or errors stating cross-sections are defaulting to critical depth?
    #10128
    igorce
    I was get warnings, not errors. In continue i share you print screen !
    Thanks in advance if you can halp me
    #10129
    igorce
    I’m still waiting for answers or comments.
    Is it possible no one can answer the questions?
    Is there a possibility to set boundary conditions in each section?
    How can we solve the problem of illogical flow?
    #10130
    The warnings you are getting are causing some of the problem. The first warning is telling you that the program did not solve for that cross-section and used critical depth for the answer. The second warning is similar. The third warning is stating that the change in conveyance between the two cross-sections is to large and may need more cross-sections. The fourth warning states you may need more cross-sections.
    Basically you may need to add/remove cross-sections, adjust roughness values, or modify cross-sections to fix the problem.
