We are seeing the same thing. In one of our models, which is also Full Momentum, we only change the time step DT from 6 sec to 5 sec. This resulted in about 0.5 ft change in WSE. Even right next to a fixed stage boundary, the change becomes almost immediate once you move away from the boundary. Both DTs would of course produce similar Courant numbers, since they’re so close. The 2D area is very large, so you cannot satisfy Courant everywhere, even if you target the high velocity zones. We are cautioned to examine DX and DT carefully when using HEC-RAS 2D, but I’m finding this code to be far more sensitive to even modest changes in DT than other 2D codes.
Full Momentum also seems to produce a lot of messages, with cells frequently maxing out on iterations and producing a not-so-insignificant errors. To locally refine the grid at each location would be very cumbersome (to the extent you can locally refine your grid). The beauty of this code is supposed to be that you don’t have to spend as much time on grid/mesh refinement, specify breaklines where needed (e.g. embankments) but otherwise rely on the subgrid.
