Welcome to the RAS Solution Forums HEC-RAS Help Sediment Transport error
  • #6174
    I am performing a sediment transport computation using quasi-unsteady flow data. The time cover a total of 43 hours, however I get an error if I try to use anything over 24 hours.
    The error that comes up is: “Sediment time series is not sufficient to run requested time window.”
    I noticed when I input the temperature data it does not allow for values to go past 24 hours.
    Is this an error on my end, or is this a limitation in the model?
