Welcome to the RAS Solution Forums HEC-RAS Help Sediment Transport Analysis – Error with sediment boudary conditions
  • #16222
    I am implementing a quasi-unsteady simulation (sediment) with HEC-RAS to quantify the amount of debris with the aim to dimension a sedimentation tank at the end of the model.
    I get this error when running the model:
    “An error occurred while reading sediment boundary data.
    Check sediment boundary condition data.
    Review your data at this location for completeness and consistency”.
    In “Sediment data” I put all the data required: “Initial conditions and Transport parameters” are complete, and in “Boundary conditions” I put “Clear water (no sediment)” at the top section.
    What can I do to fix the error?
    #17983
    Felizia Koester
    Hi Beatrice,
    I have the exact same problem. Did you find a solution? It would help a lot.
    Thank you,
    Felizia
