Welcome to the RAS Solution Forums HEC-RAS Help Sediment: data entry
  • This topic has 3 replies, 332 voices, and was last updated 9 years ago by Roger.
  • #6122
    Roger
    I’m trying to include sediment transport in an unsteady-flow analysis in RAS 5.0.1. The model has about 1200 river cross sections. In the Sediment Data window, is there a way to enter repeated Max Depth numbers (or interpolate between two numbers that are entered) without clicking on each cell and typing a number?
    #9962
    You can set up the desired table in excel and CTRL+C/CTRL+V it in…
    #9963
    Thanks a million, Tim!!
    #9964
    Zoran
    Enter a value in the Max Depth column. With your mouse go to the lower-right corner of the cell and your mouse should change to a black cross. Click on the cross and drag it down to copy the value to the next cells.
