First off you probably don’t need that many interpolated cross-sections.
If you don’t care so much for mapping then it won’t matter what the interpolated cross-sections look like in plan view as the should be using the interpolated reach lengths.
There are two types of interpolation options, one that follows the channel centerline and one that doesn’t. It does not change the actual interpolation, it just changes the visual appearance. the one that follows the centerline will keep the banks visually looking correct.
