Hello, thanks for your answer.
Yes, I’ve this option on. The problem is that Hec Ras does’n make the velocity distribution calculations inside the multi-opening estructure.
I think the only way to calculate this is entering the data manually, I will take the maximum average velocity from both upstream and downstream, which Hec Ras does calculate.
I will need to enter water surface depths for every pier manually (Hec Ras shows the water surface elevation at Multi Opening Output table) , too, because Hec Ras doesn’t do it either.
What do you think abut it?
