Welcome to the RAS Solution › Forums › HECRAS Controller › save new plan through controller
- This topic has 4 replies, 814 voices, and was last updated 9 years ago by Bharath.
March 10, 2017 at 2:04 am #8191BharathParticipant
I am modifying the geometry file within a loop in HEC-RAS controller. Is it possible to save each of these edited files as a new Geometry file or a new plan? I observe that it overwrites the same file and this doesn’t allow for parallel computing/save specific outputs.
March 11, 2017 at 1:13 am #13533Chris G.KeymasterYes, just give it a each new file a new name. If you want to stay consistent with RAS convention, keep the project name the same, just change the file extension (e.g. Project.g01, Project.g02, etc). You may have to rewrite the project and plan files accordingly so that RAS recognizes the new files.
March 11, 2017 at 1:52 am #13534BharathParticipantOnce again, Thanks a lot Chris. Does doing so affect the hdf file associated with the geometry file? Like am i supposed to create a new hdf file for a new geometry file?
March 11, 2017 at 7:24 am #13535Chris G.KeymasterReturn-Path:
Received: from mail-pg0-f47.google.com (mail-pg0-f47.google.com [74.125.83.47])
by mwork.nabble.com (Postfix) with ESMTP id DE2E832255673
for; Fri, 10 Mar 2017 20:24:28 -0700 (MST)
Received: by mail-pg0-f47.google.com with SMTP id b129so45461355pgc.2
for; Fri, 10 Mar 2017 19:24:28 -0800 (PST)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to;
bh=e34ZJabSrSQpcOrJfiTutJ+P417K6j+XtEN27qnIt+k=;
b=fQCBIfKCm4fzw9extOtOVnqeNp1RystPsu/IX1ljuWJQSRrw4EzySLx6xuBH06VL11
YmVfVocDxAnqKQM2EV+8cwPnwX6ji4biaelFX/88gX1JDf8HNpeoPlC0LfTZFHzjC/CO
1lk9C3lpLju4gI+F+43GB8cEWXpa+e+OKIeVtyfkrVBnArjmbs/6f5KpyTLAa2V7BhK6
tro/YoA7wSrsWNpTO8fwdgP51v7DnvRbOQ/N41OnXK3JY+/F8a+1buOHR3MZ/Orak/rq
vD0LmsZ1BmMUX+2+sFIo4pMbLnw/KLNN2rlkxRm7s1E5TKwRlV8oNrrsaa8m+cuMwvJs
c+4w==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=nRtIaNOjU8ENyQKfAYwLeb0VzXi3e9869PqYA0FNXWPAEdBiSPk/P4Q6wpG/jmlsoy
olcG/NV7vJWIhYg1ooaY97GkmOfn6SDA5VXZKPAJFYI35lZnYflluNMvBfWbnMRQrkSb
JVtj3seI6AopWaZ8DNvd/NoY1sZFpS/EkytTQfglsAFir4mSFy+vgA9uEAaxGfLSm4lR
qPd/+Ds67dPvBoaB12cA21x1JterNlDFUXq/hakYq5QtP7qCN8/Jy2xrmTlB24E49AfY
NNdCWiuvGqunIAIECovP0SRzMRc0SiREKYUZSdhsqk1pHLnZpG5l972FL3OMFr195tlr
EJ4g==
X-Gm-Message-State: AMke39lS6W/xFULtxBRkW7BI3XrvRkTOcWTfZ2iMzaepLYitEAY7uzCPiV2Z2HD/nLJQhA==
X-Received: by 10.99.125.68 with SMTP id m4mr24541538pgn.13.1489202661879;
Fri, 10 Mar 2017 19:24:21 -0800 (PST)
Received: from [192.168.1.5] (c-73-37-84-115.hsd1.or.comcast.net. [73.37.84.115])
by smtp.gmail.com with ESMTPSA id v9sm20980350pfg.133.2017.03.10.19.24.21
for
(version=TLS1 cipher=ECDHE-RSA-AES128-SHA bits=128/128);
boundary=Apple-Mail-F9A7553B-4BEC-4C2B-BD85-465486B090A0
Mime-Version: 1.0 (1.0)
Date: Fri, 10 Mar 2017 19:24:20 -0800
Subject: Re: save new plan through controller
References: <[email protected]> <[email protected]> <[email protected]>
To: “Bharath [via HEC-RAS Help]”
X-Mailer: iPhone Mail (14A456)–Apple-Mail-F9A7553B-4BEC-4C2B-BD85-465486B090A0
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableOnce you bring in the newly created Geometry file, delete the associated HDF=
file. Then save the geometry in RAS. That will force RAS to rewrite the HDF=
file for the new geometry.=20Sent from my iPhone
> On Mar 10, 2017, at 1:52 PM, Bharath [via HEC-RAS Help]
wrote:
>=20
> Once again, Thanks a lot Chris. Does doing so affect the hdf file associat=
ed with the geometry file? Like am i supposed to create a new hdf file for a=
new geometry file?=20
>=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/save-new-plan-through-controller=
-tp3736p3739.html
> To start a new topic under HECRAS Controller, email ml-node+s1091112n1184h=
[email protected]=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-F9A7553B-4BEC-4C2B-BD85-465486B090A0
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitOnce you bring in the newly created Geometry file, delete the associated HDF file. Then save the geometry in RAS. That will force RAS to rewrite the HDF file for the new geometry.Sent from my iPhone
On Mar 10, 2017, at 1:52 PM, Bharath [via HEC-RAS Help] <[email protected]> wrote:Once again, Thanks a lot Chris. Does doing so affect the hdf file associated with the geometry file? Like am i supposed to create a new hdf file for a new geometry file?
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/save-new-plan-through-controller-tp3736p3739.html
To start a new topic under HECRAS Controller, email [email protected]
NAML
–Apple-Mail-F9A7553B-4BEC-4C2B-BD85-465486B090A0–August 2, 2019 at 9:19 pm #13536AnonymousGuestI think this thread gets at my question, but I want to clarify.
I have a plan set up using g01 file, and I am using VBA/RASController to
1. run the plan p01
2. get a WSE from that plan and test it against a target WSE
3. Rewrite the g01 file (using a g01temp as intermediate file) with new geometry for a single cross section.
4. rerun the plan p01 with the updated g01 file.
5. test the WSE again, and if necessary, repeat.I’m not sure RC.Project_Save is achieving the goal of RAS recognizing the new g01 file after the text is modified. Do I need to RC.Quit_RAS between every step? Do I just need to write to a different geometry file (g02) and then have a different plan (p02) and open it after the modifications have been made, then run the new plan?
I am doing this on a geometry file that is +50k lines so I need it to be as efficient as possible.
