Welcome to the RAS Solution Forums HEC-RAS Help Same DS and US flows in lateral structure output
  • #7625
    kamal22b
    I should have done something wrong while modeling this storage area and lateral structure in 1d. There are few results that doesn’t make sense to me.
    1. I have same flows in channel at the upstream and downstream of the lateral structure output even though it shows a percentage of flow leaving from the lateral weir.
    2. The storage only takes the flow from the lateral flow and doesn’t add up with the flow coming from it’s (pond) upstream cross section.
    3. The discharging pipes only take the flows coming into the pond from upstream cross section(pond’s upstream) to further downstream where these pipes meet with the channel.
    Will appreciate if someone could help me to figure out this issue.
    Kamal
