Welcome to the RAS Solution Forums HEC-RAS Help Running Temperature Model
  • #6185
    Hello – I have a model that is set up and calibrated for hydrodynamic modeling and I need to add temperature. When I set up the WQ file and try to run it in version 4.1.0 it pops up the dialog box but does nothing. No errors, no sign of processing, nothing. If I hit stop it comes up and says the process was stopped by the user and there’s no sign that anything was done. I can run the example WQ model with this installation of HEC RAS. If I try it in version 5.0.2, I get an error message “Error with program: WQNet.exe Exit Code = -1073741515” I have tried everything I can think of including setting WQ parameters to constant values, etc. Any ideas on what I should try?
