Welcome to the RAS Solution › Forums › HECRAS Controller › Running HEC-RAS from a loop in MATLAB with different unsteady flow data
- This topic has 4 replies, 221 voices, and was last updated 5 years, 8 months ago by Tcollings.
July 9, 2020 at 8:06 pm #8248TcollingsParticipant
Hi guys,
I’m trying to run HEC-RAS with a load of different unsteady flow data. I’ve written a loop in matlab which edits the unsteady flow file for the current plan in HEC-RAS, and the program seems fine running the file outside of the loop.
However, once I run HEC-RAS inside the loop (i.e. initiate a new instantance of HEC-RAS and open project file with current plan using the unsteady flow file that has just been edited), HEC-RAS doesn’t seem to read the newly edited unsteady flow file, but just runs using the original unsteady flow file from before the loop was started. I can’t work out how to get HEC-RAS to read the unsteady flow file that has just been edited by the loop.
I would have thought that everytime HEC-RAS runs it re-reads the flow files, or at least re-reads them on reopening the project? Does anyone have any ideas? I’m hoping someone might have done this before.
Cheers,
Tom
July 10, 2020 at 12:44 pm #13616TcollingsParticipantI have managed to solve it.
Matlab wasn’t waiting for HEC-RAS to run and so was closing the program almost immediately after opening it. By simply adding a pause(10) and making the loop pause for 10 seconds, matlab now gives hecras enough time to run before reading out the outputs and closing the program.
Cheers,
Tom
July 27, 2020 at 1:44 am #13617SILVIA HEREDIAParticipantHi Tcollings!! I read your post and think you can help me out a bit.
I would like to make a code in Hec-Ras in order to multi-run several unsteady flow data. Can you give any advice about it? This is my first time doing it, so maybe some references will help.
Thank you!!July 27, 2020 at 11:52 am #13618TcollingsParticipantHi Silvia,
Happy to help. I used this paper a lot as the basis of my code – http://www2.egr.uh.edu/~aleon3/papers_PDF/Journal/HEC_RAS_Controller.pdf
Below is the loop I wrote complete the task. Feel free to get in touch if it needs more explaining.
Cheers,
Tom
% outputs
reach_in= [1,1,2,3]; % 1 = Upper, 2 =Saltash, 3 = Devonport
Ri_St_in=[42,50,4,4];% 42 = 3905, 50 = 5018, 4 = 2526, 4 = 1251for ii = 1:5 % Tides
disp(ii)
for jj=1:7 % Surges
for kk = 1:7 % Lag
Tide_in=Tide(Lag(:,kk),ii)+(Surge(Lag(:,kk),jj).*Surge_cont(Lag(:,kk))’); % create stage boundary condition to rewrite HEC-RAS input file
for pp = 1:192
if Tide_in(pp) <0 %formatting the numbers to the correct format to paste into the input file
Tide_in_str{pp}=num2str(Tide_in(pp),'%.5f');
else
Tide_in_str{pp}=num2str(Tide_in(pp),'%8f');
end
end
Tide_in_str=string(Tide_in_str);
% the code above here formulates the unsteady flow data to be
% input in the hec-ras unsteady flow filefilenameinput = ('C:\Users\Tom\Documents\HECRAS\TamarTavyEstuary_TEMP.u15');
filenameoutput = ('C:\Users\Tom\Documents\HECRAS\TamarTavyEstuary.u15');
copyfile(filenameoutput,filenameinput);
fid = fopen(filenameinput, 'rt');
fout = fopen (filenameoutput , 'wt');while ~feof(fid)
strTextLine = fgetl(fid); %To read one additional lineif strfind(strTextLine,'Stage Hydrograph= 192 ') % find line to enter new stage data below
fprintf(fout,'%s\n',strTextLine);
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(1:10));
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(11:20));
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(21:30)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(31:40)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(41:50)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(51:60)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(61:70)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(71:80)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(81:90)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(91:100)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(101:110));
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(111:120));
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(121:130)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(131:140)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(141:150)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(151:160)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(161:170)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(171:180)) ;
fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(181:190)) ;
fprintf(fout,'%s%s',Tide_in_str(191:192)); %print in the new data line by line
fseek(fid,1574,'cof'); % skip forward in the reading file to the next line below the old input data
else
fprintf(fout,'%s\n',strTextLine); % copy line into the new input file
end
end
fclose(fid);
fclose(fout);
h=actxserver('RAS507.HECRASCONTROLLER'); %start hecras in the background
h.Project_Open('C:\Users\Tom\Documents\HECRAS\TamarTavyEstuary.prj'); %open project file
h.Compute_HideComputationWindow;
h.Plan_SetCurrent('Plan 24');
h.Compute_CurrentPlan(0,0);
pause(12) % pause necessary to allow Hec-ras time to run the model before matlab reads the output and closes it
run_check(ii,jj,kk)=h.Compute_Complete() % checks if HEC-RAS has run - if 0, increases pause timefor ll = 1:4
for mm = 2:193
z=h.Output_NodeOutput(2,reach_in(ll),Ri_St_in(ll),0,mm,2); %read output (WS elevation) for the 4 river stations
WS_elv(mm-1,ll)=z; %save into mega matrix for processing and analysis
end
end
h.Project_Save;
h.Project_Close()
h.QuitRas%WS_elv=run_hec();
WS_El(:,:,ii,jj,kk)=WS_elv; %save into mega matrix for processing and analysis
clear Tide_in
clear z
clear Tide_in_strend
end
endJuly 28, 2020 at 7:17 am #13619SILVIA HEREDIAParticipantReturn-Path:
by sloti1d2t14 (Cyrus 3.3.0-92-g11c785d-fm-20200721.004-g11c785d5) with LMTPA;
Mon, 27 Jul 2020 23:17:56 -0400
X-Cyrus-Session-Id: sloti1d2t14-1595906276-1019952-2-5338876426284943849
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-sender-reputation: 500 (none)
X-Spam-score: 0.1
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_SENDERREP_NEUTRAL 0.001,
RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H2 -0.001,
SPF_HELO_NONE 0.001, SPF_PASS -0.001, URI_HEX 0.1, LANGUAGES en,
BAYES_USED none, SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.219.180′, Host=’mail-yb1-f180.google.com’, Country=’US’,
Received: from mx3 ([10.202.2.202])
by compute1.internal (LMTPProxy); Mon, 27 Jul 2020 23:17:56 -0400
Received: from mx3.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 2249019600B1
for; Mon, 27 Jul 2020 23:17:56 -0400 (EDT)
by mx3.messagingengine.com (Authentication Milter) with ESMTP
id AEB48B635CB;
1595906276; b=mTQy0P3umn3lz2nXmHdN6NZyAYzhJyE6hvZKUdfK2jl+Y71Di5
f7KQUFGGhnJeWFiq6R8MpKv4JR2vWK9snTT+kGgdrywQnSCM8sWzj9qRqxEUdyQC
hABzG8RKSJuCb1BaF2e/lKsZGlCX6kLf5wJOJG13xUCkZ326SkBhRMaZFL6Pvyx4
rwj+Ec3mZcX5PWZ8WiQf0tyuiJ8FmNTIJQsyebiK5StD6WeEgbRLErIN2XPA4R+6
ycmiP8xCXrepHoAXo2rGK6dzU4fccqXuXw63CFzsTI9uCeMmFS2i99WKK61xqPAT
tqiOvq7bRpSLGrMvxd6tGHey5ma22Fpg3N3A==
:date:message-id:subject:to:content-type; s=fm3; t=1595906276;
bh=lifb6gmNEEZ5vT5/Sj8oCrkjqr1qTrUgcGyObb3KgSM=; b=JYY7Q2bIlriy
EA9kLgFvSSZC8HdpnC8OmlvQZsTGz/4mD1LzWJsRhYDBVyjsg+tdnOoE1BhyqEjW
XK25O8cgkfN94UWUAUHGyQ8+GB2EVTKUlBpl2v6JWzyP22K00fyYvzVkUj+GlPuE
Phh/+6rRrSJl8wsnukUs5DGzi/hwAffZlhFSraVSL1/LCezm4rVkeVoTBzt6FN/5
YD+oPedCR0hsdtBycJ+S5t0XLtU4n8SmcrFqt1jQPk3LesNWZSmC+MQ/CDHQtTIp
kTTGTCcAxgFVqPBFF+yIUzUi8vajWPIwBl/yTGmuCsCncIszXblfNy3SYhVJoS80
185KZy49nQ==
ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
bimi=none (Domain is not BIMI enabled);
[email protected] header.b=HPBdO79/ header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.219.180 (mail-yb1-f180.google.com);
spf=pass [email protected]
smtp.helo=mail-yb1-f180.google.com;
[email protected] header.b=szZ4jFfx;
x-ptr=pass smtp.helo=mail-yb1-f180.google.com
policy.ptr=mail-yb1-f180.google.com;
(MX Records found: alt1.gmail-smtp-in.l.google.com,gmail-smtp-in.l.google.com,alt2.gmail-smtp-in.l.google.com,alt3.gmail-smtp-in.l.google.com,alt4.gmail-smtp-in.l.google.com);
smtp.bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx3.messagingengine.com;
smtp.bits=128/128;
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT05
MDA4JmNvZGU9YzJsc2RtbGhhR1Z5WldScFlXeGhRR2R0WVdsc0xtTnZiWHc1TURBNGZDMD
BOek01TVRRMU5UZz0
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgeduiedriedugdeikecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgdpuffr
tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecunecujfgurhepgghfjgfhff
fkuffvtgesrgdtreertddtjeenucfhrhhomhepufhilhhvihgrucffihgrnhgrucfjvghr
vgguihgrucfnrghrrgcuoehsihhlvhhirghhvghrvgguihgrlhgrsehgmhgrihhlrdgtoh
hmqeenucggtffrrghtthgvrhhnpeeigfegveegveetudevfedtlefhveduieevveeijeev
ieehtdegfeeuieffvdfgteenucffohhmrghinhepuhhhrdgvughupdhnrggssghlvgdrtg
homhenucfkphepvddtledrkeehrddvudelrddukedtnecuvehluhhsthgvrhfuihiivgep
tdenucfrrghrrghmpehinhgvthepvddtledrkeehrddvudelrddukedtpdhhvghlohepmh
grihhlqdihsgduqdhfudektddrghhoohhglhgvrdgtohhmpdhmrghilhhfrhhomhepoehs
ihhlvhhirghhvghrvgguihgrlhgrsehgmhgrihhlrdgtohhmqecuuffkkgfgpedvuddtie
du
X-ME-VSScore: 0
X-ME-VSCategory: clean
Received-SPF: pass
receiver=mx3.messagingengine.com;
identity=mailfrom;
client-ip=209.85.219.180
Received: from mail-yb1-f180.google.com (mail-yb1-f180.google.com [209.85.219.180])
by mx3.messagingengine.com (Postfix) with ESMTPS
for; Mon, 27 Jul 2020 23:17:55 -0400 (EDT)
Received: by mail-yb1-f180.google.com with SMTP id 133so9863647ybu.7
for; Mon, 27 Jul 2020 20:17:55 -0700 (PDT)
d=gmail.com; s=20161025;
b=HPBdO79/aVMZbdiSBErzZnoO2mWLdNTOEPmjWM9HB+DJXJ059ZUaTMteLfa/ORNujk
+3Wxl8zsDJMb1QSmVLw3fNI208DevOnUW4vvyyx0Rm0DQSbWox51Dp2s3vV8V8HtYMV8
HH2L4D96vtWmOHAczTpRecy3IE/pHs1PiOk/LamrY5kvRAHbu1jJTgEBY5rcjtSVV7rZ
1QmTIRTANWaphej2M0bUciObnFSHcO8HV9gcDn8BVXEmBqkgMZcFfcuIGus0RkTuWHE9
dwaQgPlnr26iBoGirf0PIoBpYapRQohrMGTRXXzdeo61gNQumxyrCIU4WUJtwmJUOwRW
jQSg==
d=1e100.net; s=20161025;
b=szZ4jFfxBBSdPOtsP77dmorD1+Qdq+l5MZP/u+N5B/tZSDgndz1KxH99QjljIs37dj
pwEwXOH6xqJ1PVem2qZHDONrzRxsopAy18jRq0V59xtw/EvZ0kAdGXB8yehaIsm3i+Dw
5tBs5j5117gCZv7eCK1DEGpEwqbN2ccupdtaM9qJO9Wp/AWR3W/sGxLEFWkgGl+X5EdR
xJofJEfgHeBw3CSj6qjiFn98rEvPmDxpWQE165eZLMAszbWTTyvqk5I2V+7DBaVcvgIQ
DrDdOtNjMxodFPi1wK/PbqtDrkutmnouBcw4MK2D6dCgsKlcMgWbHA3rsUSfgoWwajdT
5hHg==
X-Gm-Message-State: AOAM530ZOLDh6/DnA8TyEO8D3IaY23v6oWeoQKCfHbF35svoFWTJUVMl
pC/L3TpEKxLBYfitclSecosbP4gG1y4Q+zeC7wgqBsyy
X-Google-Smtp-Source: ABdhPJykclXwPqkjYM53vyLDsfYTn6om+g0/jUqgrB0/hA7b7xfxi34+ET+BLndXl5uXxjJM9GcYghKtYbZOGbytVBo=
X-Received: by 2002:a25:328e:: with SMTP id y136mr1042576yby.281.1595906274016;
Mon, 27 Jul 2020 20:17:54 -0700 (PDT)
MIME-Version: 1.0
Date: Mon, 27 Jul 2020 22:17:42 -0500
Message-ID:
Subject: Re: Running HEC-RAS from a loop in MATLAB with different unsteady
flow data
To: “Tcollings [via HEC-RAS Help]”
Content-Type: multipart/alternative; boundary=”0000000000008ebedc05ab77e2f5″–0000000000008ebedc05ab77e2f5
Content-Transfer-Encoding: quoted-printableThank you so much for your help! you’ll hear from me soon.
Wish me luck !!Silvia
El lun., 27 jul. 2020 a las 2:52, Tcollings [via HEC-RAS Help] (< [email protected]>) escribi=C3=B3:
> Hi Silvia,
> Cheers,
> Tom
> % outputs
> reach_in=3D [1,1,2,3]; % 1 =3D Upper, 2 =3DSaltash, 3 =3D Devonport
> Ri_St_in=3D[42,50,4,4];% 42 =3D 3905, 50 =3D 5018, 4 =3D 2526, 4 =3D 1251
> for ii =3D 1:5 % Tides
> disp(ii)
> for jj=3D1:7 % Surges
> for kk =3D 1:7 % Lag
> Tide_in=3DTide(Lag(:,kk),ii)+(Surge(Lag(:,kk),jj).*Surge_cont(Lag(:,kk))’=
> for pp =3D 1:192
> Tide_in_str{pp}=3Dnum2str(Tide_in(pp),’%.5f’);
> else
> Tide_in_str{pp}=3Dnum2str(Tide_in(pp),’%8f’);
> end
> end
> Tide_in_str=3Dstring(Tide_in_str);
> filenameinput =3D
> (‘C:\Users\Tom\Documents\HECRAS\TamarTavyEstuary_TEMP.u15’);
> filenameoutput =3D
> (‘C:\Users\Tom\Documents\HECRAS\TamarTavyEstuary.u15’);
> fid =3D fopen(filenameinput, ‘rt’);
> fout =3D fopen (filenameoutput , ‘wt’);
> while ~feof(fid)
> strTextLine =3D fgetl(fid); %To read one additional line
> if strfind(strTextLine,’Stage Hydrograph=3D 192 ‘) % find
> fprintf(fout,’%s\n’,strTextLine);
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(1:10));
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(11:20));
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(21:30)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(31:40)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(41:50)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(51:60)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(61:70)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(71:80)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(81:90)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(91:100)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(101:110));
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(111:120));
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(121:130)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(131:140)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(141:150)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(151:160)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(161:170)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(171:180)) ;
> fprintf(fout,’%s%s%s%s%s%s%s%s%s%s\n’,Tide_in_str(181:190)) ;
> fprintf(fout,’%s%s’,Tide_in_str(191:192)); %print in
> fseek(fid,1574,’cof’); % skip forward in the reading
> else
> fprintf(fout,’%s\n’,strTextLine); % copy line into th=
e
> new input file
> end
> end
> fclose(fid);
> fclose(fout);
> h=3Dactxserver(‘RAS507.HECRASCONTROLLER’); %start hecras in t=
he
> background
> h.Project_Open(‘C:\Users\Tom\Documents\HECRAS\TamarTavyEstuary.prj’); %op=
en
> project file
> h.Plan_SetCurrent(‘Plan 24’);
> run_check(ii,jj,kk)=3Dh.Compute_Complete() % checks if HEC-RA=
S
> has run – if 0, increases pause time
> for ll =3D 1:4
> for mm =3D 2:193
> z=3Dh.Output_NodeOutput(2,reach_in(ll),Ri_St_in(ll),0,mm,2); %read output=
(WS
> WS_elv(mm-1,ll)=3Dz; %save into mega matrix for
> end
> end
> h.Project_Save;
> h.Project_Close()
> h.QuitRas
> %WS_elv=3Drun_hec();
> WS_El(:,:,ii,jj,kk)=3DWS_elv; %save into mega matrix for
> clear Tide_in
> clear z
> clear Tide_in_str
> end
> end
> end
> below:
> http://hec-ras-help.1091112.n5.nabble.com/Running-HEC-RAS-from-a-loop-in-=
MATLAB-with-different-unsteady-flow-data-tp9008p9057.html
> To unsubscribe from Running HEC-RAS from a loop in MATLAB with different
> unsteady flow data, click here
=3Dunsubscribe_by_code&node=3D9008&code=3Dc2lsdmlhaGVyZWRpYWxhQGdtYWlsLmNvb=
Xw5MDA4fC00NzM5MTQ1NTg=3D>
> NAML
%3Aemail.naml>
>–=20
*M.C. Silvia Diana Heredia Lara*
+52 999 412 5499
*”Water is the driving force of all nature”*–0000000000008ebedc05ab77e2f5
Content-Transfer-Encoding: quoted-printableThank you so much for your help! you'll hear from me s=
oon.Wish me luck !!=C2=A0Silvia=
El lun., 27 jul. 2020 a las 2:52, Tcollings [via HEC-RAS Help] (<[email protected]=
le.com>) escribi=C3=B3:tyle=3D"margin:0px 0px 0px 0.8ex;border-left:1px solid rgb(204,204,204);pad= ding-left:1ex">
Hi Silvia,=20
Happy to help. I used this paper a lot as the basis of my code – http://www2.egr.uh.edu/~aleon3/p=
apers_PDF/Journal/HEC_RAS_Controller.pdf=C2=A0Below is the loop I wrote complete the task. Feel free to get in to=
uch if it needs more explaining.Cheers,
Tom
% outputs
Ri_St_in=3D[42,50,4,4];% 42 =3D 3905, 50 =3D 5018, 4 =3D 2526, 4 =3D 12=
51for ii =3D 1:5 % Tides
=C2=A0 =C2=A0 disp(ii)
=C2=A0 =C2=A0 for jj=3D1:7 % Surges
=C2=A0 =C2=A0 =C2=A0 =C2=A0 for kk =3D 1:7 % Lag
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 Tide_in=3DTide(Lag(:,kk),ii)+=
(Surge(Lag(:,kk),jj).*Surge_cont(Lag(:,kk))'); % create stage boundary =
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 for pp =3D 1:192
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0if Tide_in(pp) &=
lt;0 %formatting the numbers to the correct format to paste into the input =
file
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0Ti=
de_in_str{pp}=3Dnum2str(Tide_in(pp),'%.5f');
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0else=20
de_in_str{pp}=3Dnum2str(Tide_in(pp),'%8f');
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0end=20
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 end=20
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 Tide_in_str=3Dstring(Tide_in_=
str);
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 % the code above here formula=
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 % input in the hec-ras unstea=
dy flow file
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0=20
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 filenameinput =3D ('C:\Us=
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 filenameoutput =3D ('C:\U=
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 copyfile(filenameoutput,filen=
ameinput);
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 fid =3D fopen(filenameinput, =
'rt');
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 fout =3D fopen (filenameoutpu=
t , 'wt');=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 while ~feof(fid)
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 strTextLine =3D=
fgetl(fid); %To read one additional line=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 if strfind(=
strTextLine,'Stage Hydrograph=3D 192 ') % find line to enter new st=
age data below
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =
=C2=A0fprintf(fout,'%s\n',strTextLine);
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(1:10));
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(11:20));=20
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(21:30)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(31:40)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(41:50)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(51:60)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(61:70)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(71:80)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(81:90)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(91:100)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(101:110));
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(111:120));
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(121:130)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(131:140)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(141:150)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(151:160)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(161:170)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(171:180)) ;
=C2=A0fprintf(fout,'%s%s%s%s%s%s%s%s%s%s\n',Tide_in_str(181:190)) ;
=C2=A0fprintf(fout,'%s%s',Tide_in_str(191:192)); %print in the new =
data line by line
=C2=A0fseek(fid,1574,'cof'); % skip forward in the reading file to =
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 else
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 f=
printf(fout,'%s\n',strTextLine); % copy line into the new input fil=
e
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 end=20
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 fclose(fid);
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 fclose(fout);
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h=3Dactxserver('RAS507.HE=
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.Project_Open('C:\Users\=
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.Compute_HideComputationWind=
ow;
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.Plan_SetCurrent('Plan 2=
4');=20
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.Compute_CurrentPlan(0,0);
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 pause(12) % pause necessary t=
o allow Hec-ras time to run the model before matlab =C2=A0reads the output =
and closes it
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 run_check(ii,jj,kk)=3Dh.Compu=
te_Complete() % checks if HEC-RAS has run – =C2=A0if 0, increases pause tim=
e=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 for ll =C2=A0=3D =
1:4
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 for mm =3D 2:19=
3
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 z=
=3Dh.Output_NodeOutput(2,reach_in(ll),Ri_St_in(ll),0,mm,2); %read output (W=
S elevation) for the 4 river stations=20
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 W=
S_elv(mm-1,ll)=3Dz; %save into mega matrix for processing and analysis
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.Project_Save;
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.Project_Close()
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 h.QuitRas
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 %WS_elv=3Drun_hec();
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 WS_El(:,:,ii,jj,kk)=3DWS_elv;=
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 clear Tide_in
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 clear z
=C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 clear Tide_in_str
end=20=09
=09
=09
=09
To unsubscribe from Running HEC-RAS from a loop in MATLAB with different =
unsteady flow data, click here.
NAML—
<= div style=3D"text-align:center">M.C. Silvia Diana Heredia Lara+52 999 412 5499"Water is the driving force of all nature=
"–0000000000008ebedc05ab77e2f5–
