Welcome to the RAS Solution › Forums › HEC-RAS Help › Run plans on separate computers
- This topic has 5 replies, 158 voices, and was last updated 7 years, 6 months ago by Kinagoto.
September 14, 2018 at 1:09 am #7045KinagotoParticipant
Dear HEC-RAS Modelers,
I do not know if the topic of running (HEC-RAS 2D models) plans on separate computers have been discussed in this Forum in the pass.
I have a pretty long and wide Dam & Dike Breach Model I am performing using HEC-RAS 2D 5.0.5 version (20 ft x 20 ft 2D Mesh and a time step of 2 seconds with time slicing option).
The following plans have been setup:
– Warm Up
– No Breach
– Dam Breach
– Dike BreachEach plan takes about 3 days to run.
I used the Warm Up output file as ReStart file for the other plans.
After review of the results, some corrections have been made in the inflow hydrographs with baseflow consistent with the Warm Up conditions. I copy the model on three different computers and I plan to re-run the No Breach, Dam, Dam Breach, and Dike Breach plan, each on separate machine in other to optimize the capabilities offer by each computer and to save time.Once the run on each of the 3 computers are completed, can I replace the old plan sub-folders with the new ones in one of the machines and retrieve the results in on place?
I hope that I state my concern clearly.
Thanks for your guidance.
September 14, 2018 at 6:17 am #11725cameronParticipantif you have the three plans in one HEC-RAS model. you can make copies of the folder run each run on a different machine, and then copy the outputs to one of the folders and everything should be there except for data that is stored in the dss file which will also need to be copied to a single dss file
September 16, 2018 at 12:37 am #11726KinagotoParticipantThanks, Cameron.
The runs are completed.
I replace the plan folders with the appropriate one.
The dss file on each computer has the same size but different time. How to copy the dss files to a single file?
I notice that the plan hdf file for each run has change and now havedifferent size:
*.p02.hdf for No Breach
*.p03.hdf for Dam Breach
*.p04.hdf for Dike BreachShould the *.p0*.hdf be replacce as well?
September 16, 2018 at 6:10 am #11727cameronParticipantthe plan hdf files are what contain most of the results and are the most important files to to copy over.
To copy the dss data, you need to open them in DSSVue and copy into one of them.
September 16, 2018 at 8:54 am #11728KinagotoParticipantReturn-Path:
by sloti1d2t14 (Cyrus 3.1.5-472-gf55f9be-fmstable-20180911v1) with LMTPA;
Sun, 16 Sep 2018 00:55:03 -0400
X-Cyrus-Session-Id: sloti1d2t14-4090379-1537073703-2-6816762176162448994
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 1.3
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_BETA_RULES 0.01,
RCVD_IN_DNSWL_NONE -0.0001, SPF_PASS -0.001, URI_HEX 1.313, LANGUAGES en,
BAYES_USED none, SA_VERSION 3.4.0
X-Spam-source: IP=’209.85.222.169′, Host=’mail-qk1-f169.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
Received: from mx2 ([10.202.2.201])
by compute1.internal (LMTPProxy); Sun, 16 Sep 2018 00:55:03 -0400
Received: from mx2.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 64987D8BB5
for; Sun, 16 Sep 2018 00:55:02 -0400 (EDT)
by mx2.messagingengine.com (Authentication Milter) with ESMTP
id A06BEAF35B4;
1537073702; b=D+gC81qZnJCIhPbDRazchnvHjOtRzCEasFbz8lyt75xrbOcXRA
KVJIMYoFxxfrtR7Jl78xsS1R36PUuWgyexa7FShAvylLMI52T0XhZtBtijnlSHyS
QYPa8cISTS2A3KPOPKbIMl4NtLYex1StjsTisSbtbg1xjNh/8n+y/2KRscfh+15d
1VF+CPIqJf4gpZLJ7ZOjYmbaPrhW6KjqNqtWBWrgukyt2lbc+ATGaYrCzFn2z7IC
AVr77p3z5GKOmx+9AVz46Kw0UqkmC6512Oj6y0G0y4+rN9pJ5eu/jHwHSKxpjr92
v3iquafWM8x77w0jupevgD7K5bF7YDu5cv2Q==
messagingengine.com; h=message-id:date:subject:in-reply-to:from
:to:mime-version:content-type; s=fm3; t=1537073702; bh=pc0uiJlFz
5iLUjM4Yl8UIZjjM6MCp88GLgJ6jCWuOQk=; b=aBL0Dm8k9LEPC/hzUS+YH4VB+
FzJpAmqZFx1jZvSEc2ZOJRb/Fr3KQrdPl2YNjQNbOwfJk39BlLou1QVWHducZyiV
LpGVnXL4lL16plHmX+gqxFrOqa8YZyuCvcwI5m/mmF2u+W0BbJ5w/cOevGqP0otI
ZYSTPqQWJ2tEvn4pu12JsBqAIalFKJxL/0C3adsVhLkS0JZplxNyoqKQKdtMx8JT
ltmLUJyW3R+hPnktP8nLAcrcx7XphxbPlcwJTDyzn1BXuLHvN5zeF2gnHLT3r7ai
B5q+oe1xF9VQ00LF65/pYH7FyIS84ms5uAM8KcCsV6zSmgTasxHSUH53l8Aeg==
ARC-Authentication-Results: i=1; mx2.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=VFpka0OU header.a=rsa-sha256
dmarc=pass (p=none,sp=quarantine,d=none) header.from=gmail.com;
iprev=pass policy.iprev=209.85.222.169 (mail-qk1-f169.google.com);
spf=pass [email protected]
smtp.helo=mail-qk1-f169.google.com;
x-cm=none score=0;
[email protected] header.b=TmW8KcfG;
x-ptr=pass smtp.helo=mail-qk1-f169.google.com
policy.ptr=mail-qk1-f169.google.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx2.messagingengine.com;
x-cm=none score=0;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT02
MzE2JmNvZGU9YTJsdVlXZHZkRzlBWjIxaGFXd3VZMjl0ZkRZek1UWjhOakUxTWpFNU1Ua3
g
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedtjedrkedugdefgecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgenuceu
rghilhhouhhtmecufedttdenucenucfjughrpefkfffujggkhffvgggtsegrtderredttd
ejnecuhfhrohhmpehkihhnrghgohhtohcuoehkihhnrghgohhtohesghhmrghilhdrtgho
mheqnecuffhomhgrihhnpehnrggssghlvgdrtghomhenucfkphepvddtledrkeehrddvvd
dvrdduieelpddujeefrddvgeegrddvudejrdegkeenucfrrghrrghmpehinhgvthepvddt
ledrkeehrddvvddvrdduieelpdhhvghlohepmhgrihhlqdhqkhduqdhfudeiledrghhooh
hglhgvrdgtohhmpdhmrghilhhfrhhomhepoehkihhnrghgohhtohesghhmrghilhdrtgho
mhequcfukfgkgfepjedtiedunecuvehluhhsthgvrhfuihiivgeptd
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfGk44qr9PAJx8PY+gKKyD/T5r1cmM8/YRU+rP/ZoX/sNgz0RfJVKmoTXbwVisq78OM5mVgitEW9AIJ0BhigOKmd03QUhwkVkUkf/24WutpIwM479SxNS
XmWm/znxIxlYukqw23rEQ7/iaEmhdGdnCPFQh2FJ+HG8+lToSaKWJaEbGmKeEfaEe2b3GgGOJ0rd3ZA1qbnRrMA37gnf55UZDo0WRmF9ILMlRcNZSRSgqX2j
X-CM-Analysis: v=2.3 cv=bKrH382Z c=1 sm=1 tr=0 a=sTfHN4Zh1uffypZ9lQbP9Q==:117
a=+nItSuO9g56z0Zd7unBBZw==:17 a=x7bEGLp0ZPQA:10 a=-T4MTTiiXKQA:10
a=JBFolyDoGHsA:10 a=9I5xiGouAAAA:8 a=pGLkceISAAAA:8 a=Gf2YewsSApl2nXYhWhUA:9
a=QEXdDO2ut3YA:10 a=zGXuBipvK0sA:10 a=BPF5QKo1pM_k5c3B0agA:9
a=LL296elLUcc23cuB:21 a=_W_S_7VecoQA:10 a=ARFN2YZ7Uv8kHtb7LS-q:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
receiver=mx2.messagingengine.com;
identity=mailfrom;
client-ip=209.85.222.169
Received: from mail-qk1-f169.google.com (mail-qk1-f169.google.com [209.85.222.169])
by mx2.messagingengine.com (Postfix) with ESMTPS
Received: by mail-qk1-f169.google.com with SMTP id h138-v6so7361713qke.8
for; Sat, 15 Sep 2018 21:55:02 -0700 (PDT)
d=gmail.com; s=20161025;
h=message-id:savedfromemail:date:subject:in-reply-to:importance:from
:to:mime-version;
bh=pc0uiJlFz5iLUjM4Yl8UIZjjM6MCp88GLgJ6jCWuOQk=;
b=VFpka0OULaKtaMgpS4yXaZyy9JIV4p5q1dZQ3uJmAbv03J8t/EiibHUwXgMeZdcRqd
iwlQ4pV8OGe+lCf0604/P5S59Mswp6Tau/mb28kVJKIoFjAL5Ihv1X727/qDaVhvE1bJ
vIaAe7SDRkRlQgSmiZmvGOReE44oMcVF2aj7mpvu1CHj+ETfDQuUvSxEYblNQXcS+0x/
cqMv8tankIqscpSRt0IVkbyFETolzw1FAvVfmG/7Md/5QsQtMDCKv+GyG6NiGjzbDc/o
rWmF+tAJ7QtuL9/9WT8piv3B+L84SxNWCf070VTu0k0arX0r7u6rkfdHxcUucrfIxe48
dqBg==
d=1e100.net; s=20161025;
h=x-gm-message-state:message-id:savedfromemail:date:subject
:in-reply-to:importance:from:to:mime-version;
b=TmW8KcfGNC4mO/l6OK1eHsj9LacALmJb30sW7sLljO8KAsOfeMAdQdmGHAPMSdHNXS
4xebFYQ2/LicRAVVcnFdyCcB7MgbEG4ECa7ekXkeDxbmjvoKvdM2PHJKhdG6WF9uxMSI
xQlflNHtxyIAHKSeZZFJ/i4kOAxt9hqv5irIJNv2V+l4GPCfmEkMg2VhkCAuMPUu8c2L
Zl4ijY0JeMVyHkQRojlDaFdaL2gPJDMJZ/OGyeAdCmDKaSqd3DmGeKxb7DqwVJm5+lri
qbd78q9LIyJl8yled4OJVvmQQW5jwneK7vKvNT15Jk8GI+BUnqbaMCNAyCSDlpxQuy+V
xcTQ==
X-Gm-Message-State: APzg51Dldhxa0DZxUwnH6lBDcUfxomqXUKWeYvPCzweM8RZVaN1FyoIP
ahtOHPkC0vlt/xAqUu9BFFX6mkCo
X-Google-Smtp-Source: ANB0VdapESZXeUE9iHxG4cIkxjmuQz7oGn7zIvkRMFzSYIJeni622vA9fmpUN20xEQ1emaZV5BHjXA==
X-Received: by 2002:a37:787:: with SMTP id 129-v6mr13285364qkh.300.1537073700377;
Sat, 15 Sep 2018 21:55:00 -0700 (PDT)
Received: from [10.254.0.1] ([173.244.217.48])
by smtp.gmail.com with ESMTPSA id e65-v6sm6608581qkf.39.2018.09.15.21.54.59
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Sat, 15 Sep 2018 21:54:59 -0700 (PDT)
Message-ID: <[email protected]>
SavedFromEmail: [email protected]
Date: Sun, 16 Sep 2018 00:54:58 -0400
Subject: Re: Run plans on separate computers
Importance: normal
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary=”–_com.samsung.android.email_768171620532290″—-_com.samsung.android.email_768171620532290
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: base64VGhhbmtzIENhbWVyb24uCgoKU2VudCBmcm9tIG15IEJlbGwgU2Ftc3VuZyBkZXZpY2Ugb3ZlciBD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—-_com.samsung.android.email_768171620532290
Content-Type: text/html; charset=utf-8
Content-Transfer-Encoding: base64PGh0bWw+PGhlYWQ+PG1ldGEgaHR0cC1lcXVpdj0iQ29udGVudC1UeXBlIiBjb250ZW50PSJ0ZXh0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—-_com.samsung.android.email_768171620532290–
September 19, 2018 at 5:10 pm #11729KinagotoParticipantCameron, Thank you very much for your guidance.
I am glad to report that the copy of plan folders, plan hdf files, and dss data went well.
The process help me save about a 4 days of run time.
I was able to have the “No Breach”, “Dam Breach” , and “Dike Breach” in a single model (on one computer) in order to prepare a summary results table of pre-breach flow and WSEL, breach flow and WSEL, Max Water Depth for Breach cases, Time for Initial rise, and Time for WSEL peak at selected location along the reaches and tributaries (using reference cross-sections).
Kinagoto
