Welcome to the RAS Solution › Forums › HECRAS Controller › Run Multiple Plans
- This topic has 6 replies, 2,791 voices, and was last updated 11 years ago by Chris G..
March 5, 2015 at 9:28 pm #8161Chris G.Keymaster
Yes…there is a “Run Multiple Plans” menu item already in HEC-RAS, but for fun, I’ve written a simple subroutine that does the same thing. This subroutine might serve as a starting point for a more sophisticated Monte Carlo simulation or an optimization run. Give it a try…
Sub RunMultiplePlans()
‘Demonstrates Project_Open subroutine and the _
Compute_CurrentPlan function in a Do-Loop to run _
mulitple plans.‘Written by Christopher Goodell
‘March 5, 2015
‘**********************************************************‘Instantiate a new HECRASController
Dim RC As New RAS500.HECRASController‘Open a new project
Dim strFilename As String
Sheets(“RASProjects”).Select
strFilename = Range(“C4”).Value ‘In Cell C4, Paste in _
path and filename of the RAS project you want to open.
RC.Project_Open (strFilename)‘Determine the number of plans
Dim blnIncludeBasePlansOnly As Boolean
Dim lngPlanCount As Long, strPlanNames() As String
blnIncludeBasePlansOnly = True
RC.Plan_Names lngPlanCount, strPlanNames(), _
blnIncludeBasePlansOnly‘Loop through the plans and run each one.
Dim i As Integer
Dim blnSetIt As Boolean
Dim lngMessages As Long
Dim strMessages() As String
Dim blnDidItCompute As Boolean
i = 1
Do Until i > lngPlanCount
blnSetIt = RC.Plan_SetCurrent(strPlanNames(i))
i = i + 1‘Compute the selected plan.
blnDidItCompute = RC.Compute_CurrentPlan(lngMessages, _
strMessages(), True)
LoopMsgBox “Done!”
‘Close HEC-RAS
RC.QuitRAS
End SubJanuary 15, 2016 at 2:00 pm #13474stephaneParticipantHi Chris,
You said “there is a “Run Multiple Plans” menu item already in HEC-RAS” in your message.
It seems that we haven’t the same HECRAS version … No Multiple Plans option in my version (last beta).
Maybe I’m wrong.
StephaneJanuary 18, 2016 at 4:58 am #13475userParticipantTo run multiple plan.
In HecRAS, under Run menu > Run Multiple Plans
February 5, 2016 at 1:14 am #13476AnonymousGuestHi!
I´m using the “Run Multiple Plans” option in order to run 48 plans that I have already set up, but my issue is that whenever it finishes a run it says “Error when loading plan data” and I have to click on the message and right after that it starts to run the next plan.
Do you know what could be happening here?Thanks in advance
February 25, 2016 at 9:13 pm #13479AnonymousGuestIs there a way to get RAS to run multiple water quality plans?
November 22, 2016 at 1:08 am #13477AnonymousGuestDid you ever receive any feedback on this question?
I getting the same error but I’m noticing that my colleague, running the same files, is not getting the error on her computer.
It occurs in versions 4.1, 5.0.1 and 5.0.3 for me.
November 22, 2016 at 2:53 am #13478stephaneParticipantReturn-Path:
Received: from nm4-vm4.bullet.mail.ir2.yahoo.com (nm4-vm4.bullet.mail.ir2.yahoo.com [212.82.96.102])
by mbob.nabble.com (Postfix) with ESMTP id 2A5FA367313E
for; Mon, 21 Nov 2016 14:44:03 -0800 (PST)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=yahoo.fr; s=s2048; t=1479768871; bh=RHUTbnh+K/mTdjT6oDGw+/J1nxfC/mlfeht9V6XvYKg=; h=Subject:To:References:From:Date:In-Reply-To:From:Subject; b=RuWYZFUIX5pDzqgwiGOjp+h1WhC6mUo33zE4B1oKeetnSDP5B3BNGk69MTfH/RA1xyjmJ59uAJPf4fKf1JSOVm8npn38i6YcIQmTHChZJjjQviyHbehvPxNpGsgYe9bOP/z+eXQGsbz2F+pFE3ZRB3s1M813rQrDVGfavMrBNU5C6l2xHurAa53VvqE0XKm22rmFO38ifekev39Sq8DKVy7IgM1PhmzkvKtj9Txu9QJF7FoJgQTz5P7iV9yejS65pu69DH44d12gOCl6VoPmYKy34zMXFbzxPZ7Z6/DUvkFhrOH6Xq7EmAbECj0uPYoWAMfCAlDfUOnrtPF/peFlIw==
Received: from [212.82.98.63] by nm4.bullet.mail.ir2.yahoo.com with NNFMP; 21 Nov 2016 22:54:31 -0000
Received: from [46.228.39.86] by tm16.bullet.mail.ir2.yahoo.com with NNFMP; 21 Nov 2016 22:54:31 -0000
Received: from [127.0.0.1] by smtp123.mail.ir2.yahoo.com with NNFMP; 21 Nov 2016 22:54:31 -0000
X-Yahoo-Newman-Id: [email protected]
X-Yahoo-Newman-Property: ymail-3
X-YMail-OSG: GWSXL9gVM1ksE_2LQ02wq1.7Qgpn5rFyfZGUnlDc7Q3tJyp
cZHQJLsCl9mnaz7O8Myn3mls9s0j29PlFRXT2OAeJC1aG__XQ3OQPwyXK78A
TSfEeF.R4zYMFDaaN1zGE.pZ36CXNQrgAyF1mOM0XnpEB0RojoijK9Kw9_ek
W08M_d8jNYuoT81TrMqNw8eqJGObSM91OJrcE4J6Qt81p9k7VlZNPNFTHI9_
1nxggn9Yy7qMNj3mqVAxyHjAhTSwGj5wbxCAcMKVOYuXGMvJ5wslbW6a3cn.
i9KjYK1DbosdNYAybfCvzqQ9R0eRsvuMIjqrfvaZpBOOVhJaaggKicqHwdti
hGuUmyFdDktC60oY2RmElgGTcCu.hytQcpzNdwy7laJ6Qdq_r8r8TV0U3L5b
VJWxrJz_Ye8FU7upM05Feqxreb6krXdWENBAKz6hForKVygyoNBMsTBcHw9a
Te0fcNFkZHjVwC7V5bLWrYcS5lKnj66B6c53eXoylQ8OL6i.Wvy9bH9DM8t8
ZkyV_W3N_HtV0y4lAXvOZ5N_elfxocBM.KEpvYZbKkapleUOb4wSobAI3
X-Yahoo-SMTP: BVMPXd.swBD4r.x2I5uY4kLBMQ–
Subject: Re: [Bulk] Re: Run Multiple Plans
To: “Greg [via HEC-RAS Help]”
<[email protected]>
<[email protected]>
<[email protected]>
<[email protected]>
Message-ID: <[email protected]>
Date: Mon, 21 Nov 2016 23:53:16 +0100
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:45.0) Gecko/20100101
Thunderbird/45.4.0
MIME-Version: 1.0
boundary=”————5CB1BA2248110373BF49EDEA”This is a multi-part message in MIME format.
————–5CB1BA2248110373BF49EDEA
Content-Type: text/plain; charset=windows-1252; format=flowed
Content-Transfer-Encoding: 8bitThe only feedback I received is that there is an option to run multiple
plans under the “RUN” menu in the project window of HECRAS.Le 11/21/2016 à 10:08 PM, Greg [via HEC-RAS Help] a écrit :
> If you reply to this email, your message will be added to the
> discussion below:
> http://hec-ras-help.1091112.n5.nabble.com/Run-Multiple-Plans-tp1398p3285.html
> To unsubscribe from Run Multiple Plans, click here
> <http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=1398&code=c2dhaWppQHlhaG9vLmZyfDEzOTh8LTE0NjM3MzI1MQ==>.
> NAML
> <http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Content-Type: text/html; charset=windows-1252
multiple plans under the “RUN” menu in the project window of
HEC-RAS Help] a écrit :type="cite"> Did you ever receive any feedback on this question?
running the same files, is not getting the error on her computer.It occurs in versions 4.1, 5.0.1 and 5.0.3 for me.
message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Run-Multiple-Plans-tp1398p3285.html
————–5CB1BA2248110373BF49EDEA–
