Welcome to the RAS Solution › Forums › HECRAS Controller › Run Monte Carlo Simulations
- This topic has 3 replies, 791 voices, and was last updated 7 years, 9 months ago by Anonymous.
June 16, 2018 at 2:56 am #8218AnonymousGuest
Hi, I am new to HEC-RAS 5.0. I currently have a 2D model for a river reach and its floodplain. Is it possible to run Monte Carlo simulations for Manning’s roughness automatically in HEC-RAS controller? Or do it in Rstudio/Matlab? It would be truly helpful if you can provide some suggestions. Thanks in advance.
June 16, 2018 at 3:45 am #13594Chris G.KeymasterReturn-Path:
by sloti1d2t14 (Cyrus 3.1.3-653-gce35ffd-fastmail) with LMTPA;
Fri, 15 Jun 2018 19:45:15 -0400
X-Cyrus-Session-Id: sloti1d2t14-3437946-1529106315-2-12907303356768830900
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: BAYES_00 -1.9, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_BETA_RULES 0.01,
MIME_QP_LONG_LINE 0.001, RCVD_IN_DNSWL_LOW -0.7, RCVD_IN_MSPIKE_H3 -0.01,
RCVD_IN_MSPIKE_WL -0.01, SPF_PASS -0.001, URI_HEX 1.122, LANGUAGES en,
BAYES_USED global, SA_VERSION 3.4.0
X-Spam-source: IP=’209.85.216.181′, Host=’mail-qt0-f181.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
by compute1.internal (LMTPProxy); Fri, 15 Jun 2018 19:45:15 -0400
by mailmx.nyi.internal (Postfix) with ESMTP id 574C4C873F
for; Fri, 15 Jun 2018 19:45:15 -0400 (EDT)
id 57FB9E0B42C;
1529106315; b=lFFZQal37AtxJTkpUVDo7x87SrsZQb33IYBzsfBAMP4mhHLIGX
muGpyeP4JUooXW4rSSgcvToUzCDwnRuznwGfKOV/+rdedLTOL9+ujRUcJJKSODHR
YbRIDL8VyOHa4VCchsFaXUnOenz/41upHpJvTc8dY/ulYZLQdzs7yRvRwyF+aLmW
qc6agloOfHf68Zvi9SOLRhwt93rnNNwnGs3LeLKBUvLVwvsN8ZDmf5hOP13cCrOi
69EekwYWK80MtHspyI4FcYD32F1sqJpven4VBAHaTSI0LKpjEbK+fW4vYoAE6zW6
1KRX9mSrzVFI732NZ8mXyljqtfwRreoLnnyg==
messagingengine.com; h=from:content-type
:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to; s=fm3; t=1529106315; bh=kA34Nai/KlN1
cizGpWNWKzNtmccdnXrJNCGc6vi1ST8=; b=kfciTU6TGrLQKBkQt+7yl78ECNL4
dIV2Il7muBs55gry21+ZQzuWuXQ/q4QgtGQ6k7UzXpvbZ7kO0jGdrgFyVWEe7fpB
J/qz5jVkaS6aD499Z/h1y3FEX82xaAqAtBhYRyZWtDZ/pzLBUczJnc74NiJLzUo4
eyTqpaqaxBeU/MAHkHO4oDYvLozXDOIgRctdBwkGu3ovfcpcG4yd7DkictXo82/M
LQwb0wGwppQqCUsC7+IcWyxuy5g0CFcwmzTwKIG4yy7htqWungb1GWJYOzrFY+i0
wyjBkQI6ERQV4J0NHulhiYb4U08QWKFHMDBQwJipbTJqG9EjTnPh/dSqTw==
ARC-Authentication-Results: i=1; mx4.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=DlamVdwT header.a=rsa-sha256
dmarc=pass (p=none,sp=quarantine,d=none) header.from=gmail.com;
iprev=pass policy.iprev=209.85.216.181 (mail-qt0-f181.google.com);
spf=pass [email protected]
smtp.helo=mail-qt0-f181.google.com;
x-cm=none score=0;
[email protected] header.b=bFDbhA84;
x-ptr=pass smtp.helo=mail-qt0-f181.google.com
policy.ptr=mail-qt0-f181.google.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=0 state=0
x-cm=none score=0;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfEEyLpaSF9pWZW+VVnUj5g0yLXff/aih1rhH1JqbtYJWKmbBE3WwkUNkTriTIW95gZHgFG10p/V8dutxDsaugLIxs3R/KiHQDtOzQXa7doHeNDBN83Bw
sUdBqnG1QF/tLwsZk4Cm2RnCcOfnuuo6jnaj+CTqjMKlpII8a0wXCTu/t+9CdbekgHDyutbgkkoup7Qc185u1Yo9r/JReFmoppUZ1vx54aGruPKW6zQNCJ7B
X-CM-Analysis: v=2.3 cv=Ls28NEVc c=1 sm=1 tr=0 a=OoaFXe+g/VdhdOs1JzoF+Q==:117
a=x7bEGLp0ZPQA:10 a=po3G2Dre0K0A:10 a=xqWC_Br6kY4A:10 a=4_-BN3WEXhEA:10
a=7mUfYlMuFuIA:10 a=9I5xiGouAAAA:8 a=5PBOvZ-YGULaZbnQ0DAA:9 a=QEXdDO2ut3YA:10
a=lg4JEFhukzMA:10 a=s0vEYBomvsMA:10 a=ruIxa44l_E5C8bk3:21 a=_W_S_7VecoQA:10
a=ARFN2YZ7Uv8kHtb7LS-q:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
identity=mailfrom;
client-ip=209.85.216.181
Received: from mail-qt0-f181.google.com (mail-qt0-f181.google.com [209.85.216.181])
for; Fri, 15 Jun 2018 19:45:14 -0400 (EDT)
Received: by mail-qt0-f181.google.com with SMTP id p23-v6so10603848qtn.6
for; Fri, 15 Jun 2018 16:45:14 -0700 (PDT)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
bh=kA34Nai/KlN1cizGpWNWKzNtmccdnXrJNCGc6vi1ST8=;
b=DlamVdwTSS0pIAFm4DmxkxAYpGgIIXfi4Iq/CSH+S7K6yoNDPlb6IRScsq7PXu7bNx
olfOqV5nctSmmawGR1gLkhQD0j28F0HJzefds/P7i3cvOaMmpkJ4otWMHPo2wlXVYJjd
iYjBeO4WdCBPYp//pGoVhL+vNHActMrc1n69ER56eOOt2VQDprgTzEMZbWI5uJaeEF5j
nmjUI3Ecyvg1TY+D+bG6Y3Atj7J8IqtuycHfmXzz4ek81II0jAWUJ3YeGSAGQmRXbrLG
8PR174M6thwgwKy3ztTGgSrfLlNav8SEQtGTXGHNkjkmu9jdqrgJ9hMTrgJoeTNb9bcI
ryBA==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=bFDbhA84sNJcfNUDZj3fzTZK6mxoLFuPDSje9/GUXV2qMWcbKe2FlV0SQLp2QV7tmD
/MvY3QCHjz9tUu/S3ljuYZGA3lk8G3e7tiOHJplSdD8bzMSGUD3K1IkCadk0/C7TVy8T
2zTuR89RHV5iOAv/pmA5UZSANusO9wlaoEB//s911yNhWlcqa5mUMN6KBqSPPJ8k5Eer
R4x+MJ9RU0ef4CtmOIdIyMYipu/7Qff+UBvVlHs0kP6i6UmTZSGAec0nm20ui6qUj9bo
GeqFhSGcxeh0fEws3Mq3iETSgtynDHf4WRmO5NhsVYJx3wFz8aO68GqgXqfusFP3c3TW
vlpw==
X-Gm-Message-State: APt69E1RVyNxjCXuZuoI1+cXPSbPP/rbUa72D1hGjcjwEyT0GKa/RIpi
mFE1zoAUvhZpDg+n9kSIZBQhlJpc
X-Google-Smtp-Source: ADUXVKIOSJlLaR3PU+m/djPHnMcnvv0z9ApiyTbW+Uo50GF0TriAmUxYm3W9dgV4xUSPPdX8TmOpAw==
X-Received: by 2002:a0c:e791:: with SMTP id x17-v6mr3228666qvn.114.1529106313281;
Fri, 15 Jun 2018 16:45:13 -0700 (PDT)
Received: from ?IPv6:2607:fb90:2e10:91ab:98be:4e62:a82a:749? ([2607:fb90:2e10:91ab:98be:4e62:a82a:749])
by smtp.gmail.com with ESMTPSA id g127-v6sm6314137qke.39.2018.06.15.16.45.12
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Fri, 15 Jun 2018 16:45:12 -0700 (PDT)
boundary=Apple-Mail-838B31CE-F383-4EFD-9143-1667F9238E2B
Mime-Version: 1.0 (1.0)
Date: Fri, 15 Jun 2018 19:45:11 -0400
Subject: Re: Run Monte Carlo Simulations
To: “Ashley [via HEC-RAS Help]”
X-Mailer: iPhone Mail (15F79)–Apple-Mail-838B31CE-F383-4EFD-9143-1667F9238E2B
Content-Type: text/plain;
charset=utf-8
Content-Transfer-Encoding: quoted-printableYes. You should be able to do what you want to do using the HECRASController=
with some code that reads/writes to the geometry text files. Evaluating 2D o=
utput will require you to read from the hdf files. Lots of information on th=
e on the web. Suggest considering getting =E2=80=9CBreaking the HEC-RAS Code=
=E2=80=9D book if you haven=E2=80=99t already.=20Sent from my iPhone
> On Jun 15, 2018, at 6:56 PM, Ashley [via HEC-RAS Help]
wrote:
>=20
> Hi, I am new to HEC-RAS 5.0. I currently have a 2D model for a river reach=
and its floodplain. Is it possible to run Monte Carlo simulations for Manni=
ng’s roughness automatically in HEC-RAS controller? Or do it in Rstudio/Matl=
ab? It would be truly helpful if you can provide some suggestions. Thanks in=
advance.=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Run-Monte-Carlo-Simulations-tp57=
74.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-838B31CE-F383-4EFD-9143-1667F9238E2B
Yes. You should be able to do what you want=
Content-Type: text/html;
charset=utf-8
to do using the HECRASController with some code that reads/writes to the ge=
ometry text files. Evaluating 2D output will require you to read from the hd=
f files. Lots of information on the on the web. Suggest considering getting =E2=
=80=9CBreaking the HEC-RAS Code=E2=80=9D book if you haven=E2=80=99t already=
.Sent from my iPhoneHi, I am new to HEC-RAS 5.0. I currently have a 2D model for a rive=
r reach and its floodplain. Is it possible to run Monte Carlo simulations fo=
r Manning’s roughness automatically in HEC-RAS controller? Or do it in Rstud=
io/Matlab? It would be truly helpful if you can provide some suggestions. Th=
anks in advance.=09
=09
=09
If you reply to this email,=
your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com=
/Run-Monte-Carlo-Simulations-tp5774.html
To start a new topic under HECRAS Controller, email [email protected].=
com
NAML=
–Apple-Mail-838B31CE-F383-4EFD-9143-1667F9238E2B–
June 16, 2018 at 11:13 pm #13595AnonymousGuestOkay. Thanks so much.
September 2, 2019 at 11:39 am #13596nymeriaParticipantPlease give insight into whether I can run monte Carlo simulation using an ensemble of DEMs using HEC RAS
