Hello. I am new in working with pumps in HecRas and my first model is not quite simple, so some advice could be very helpful.
I have a model with 2 cascade reservoirs and 1 storage (please see attachments). I need to pump the water from the Reservoir 2 in the Storage and after that discharge back from the Storage in the Reservoir 2.
The storage is located with 150 m above the Reservoir 2, on a very high hill. Which is the best option for modeling the discharge back in the Reservoir 2? My approach was to create the dam with the spillway and a fictive channel but the difference in level is too big so the model doesn’t run. In the reality, the water discharge is done under the ground with a spillway directly in the right bank of Reservoir 2.
Is it possible to introduce a reverse pump (pumping and abstracting) in HecRas? Is it possible to describe a pump without the pump curve?
Regards,
Cristina
