Welcome to the RAS Solution Forums HEC-RAS Help results average velocity
  • This topic has 2 replies, 93 voices, and was last updated 7 years ago by Anonymous.
  • #7208
    i am trying to generate a map af average velocity. In ras maper it’s possible in the window ” results map parameters” to hace minimum and maximum for WSE, velocity… is it possible to get the average?
    #12063
    No you would have to do that in GIS (Arcmap)
    #12064
    When calculating the velocity, the max velocity might be right when a grid cell gets wet for the first time and be unrealistic. If you really care about velocity, then you should run a hotstart/restart to resolve that issue.
