Welcome to the RAS Solution Forums HEC-RAS Help RESTART FILE ERROR
  • This topic has 2 replies, 498 voices, and was last updated 6 years ago by Anonymous.
  • #7451
    Hello everybody,
    I’am performing a fully 2d flood modelling simulation, and I’am using a restart file as initial conditions in the 2D area.
    I chosed the option “write the initial conditions at the end of the simulation”.
    However wen I start the flood simulation I get this error: ” Error with restart file – an error occurred while reading the restart file – Recreating the restart file might help”. I tried rerunning but still shows the same error. What might be the reason behind this? How can I solve this problem?
    #12530
    do u modify data after simulation??
    #12531
    restart file error due to rapid change in flow condition .so first you have to the model for warm up condition that means you have to go unstady flow data then initial condition.In initial condition u have to chose second condition initial promt.after this you have to run the model such as 1 MAR to 15 MAR.Befor run the model you have to go output options which is the condition u run the model in second term.after complete the process,you chose unstady data >initial condition>restart file>prompt the file and search such as p69 if u run the model by giving the name plan 69 .After selection,you have to run the model from the date u chose to run and complete the process
