Welcome to the RAS Solution Forums HEC-RAS Help resolution in RAS mapper
  • This topic has 0 replies, 311 voices, and was last updated 10 years ago by Anonymous.
  • #6004
    cual es la resolución más baja que se puede generar en un raster para crear el terreno en ras mapper? Estoy tratando de cargar el terreno y la resolucion de los pilares del puente son de 0,44 metros es muy pequeña entonces cuando genero el raster en arcgis para convertirlo a .flt y crear el terreno en ras mapper me da un error al crear el terreno, porque la resolucion de mi raster es muy pequeña … y si hago el raster mas grande no se observa el detalle de las pilas del puente.. es para mi trabajo finalen la universidad
    anyone knows Which is the lowest resolution can be generated in That a raster to create
      which is the lowest resolution that can be generated in a raster to create the terrain mapper flush? I’m trying to load the terrain and the resolution of the pillars of the bridge are of 0.44 meters is very small when I generate the raster arcgis .flt to convert it to the ground and create mapper flush gives me an error when creating the field because my raster resolution is very small … and if I make the biggest raster detail of bridge piers is observed .. is for my college work finalen I am from Venezuela
    this is the image
    https://www.dropbox.com/sh/trc9e3sgciqgvro/AAAg9HL8nFy76bwaUh3vsiENa?dl=0
