In the figure below a tributary is shown contributing flow from the upper right. At the lateral structure, which dips to match the topography across the channel, traced particles are not shown entering the 1D reach. The traced particles bend toward the lower right, toward the downstream cross-section. Is this something I should be concerned about? Or is it just a peculiarity about the rendition?
On a second matter, the geometry shown in the image has an interpolated cross-section positioned right on the alignment of the tributary. It is there to support 1D stability, but its left bank does not lie down in the tributary channel. It is higher. Would this limit flow from the tributary from entering the 1D reach, or would the low lying lateral structure deliver flow the the 1D reach anyway?
The particle tracing makes its bend even if the interpolated cross-section is not there.
