Welcome to the RAS Solution Forums HEC-RAS Help Rectangular Canal with kinks (local energy losses)
  • This topic has 3 replies, 60 voices, and was last updated 6 years ago by Anonymous.
  • #7649
    Hello
    I am not sure, whether HEC Ras is the right instrument for what I’m trying to do but I think it should be possible. My system is quite simple: I have a bending rectangular canal, it has 4 45° kinks. Now I did create the canal and run the simulation (Fr is slightly above 1 so supercritical). What Im not able to simulate are the 4 kinks. I expect an energy loss of about 0.1 x velocity head each 45° angle (this is my assumption).
    How can I add the local energy loss to my model? (Also, do you think 0.1 x veloctiy head is a valid assumption?)
    Thanks a lot 🙂
    Carmen
    #12775
    For steady flow:
    From the flow data editor under options select known changes in WS and EG. You can add an extra loss that is a coefficient multiplied by the velocity head. I would suppose you would want to use at least 0.1.
    If you wanted more accuracy you could use 2D flow.
    #12776
    Hi Jarvus
    Thank you so much, it works!
    One more question you might be able to answer: I have supercritical flow. I understand, that the disturbancies (I have several, 4 kinks as mentioned) then only affect the downstream part. But: when I run the simulation with supercritical flow only the last local energy loss is taken into account at all. Is this a mistake of the program or do I misunderstand the hydraulics?
    Do I need to enter a time series in order to run it 2D? (I only need a constant flow of 45m3/s.)
    Best wishes, Carmen
    #12777
    For super critical flow the effect of the extra energy loss should be visible immediately downstream.
    If you only see a change at the very downstream end that seems questionable.
    Make your coefficients a little bigger and check if you are getting a difference immediately downstream of each kink. If you are not then you may have a data mistake.
    I have not used the coefficients with super critical flow but I would presume they should work.
    For 2D flow you can just do a long time series with a constant flow. A bigger issue is that you will have to create a terrain. If you are brand new to this that could be some work.
