Welcome to the RAS Solution Forums HEC-RAS Help Read *.sed02 output file
  • #7133
     Hello, everyone.
     I have a simple question.
     After sediment transport simulation in HEC-RAS 5.0.1, **.sed02 output file is generated.
     I want to read this file without HEC-RAS running (i.e., just reading it in notepad).
     Is it possible? I tried to convert that binary file to normal text file(hdf5 to txt), but failed..
     Does sombody can give a hint? or related references?
    #11923
    I’m not aware that there is anyway to read the *.sed## file. That file contains the output for the “old sediment” style output.
    It is possible to read the hdf output that also contains the new sediment output. This is the *.p##.hdf file.
    You can download a free copy of HDFView and use that to look at the file.
