Welcome to the RAS Solution › Forums › HEC-RAS Help › Reach Junction
- This topic has 1 reply, 1,172 voices, and was last updated 10 years, 12 months ago by Anonymous.
March 31, 2015 at 10:00 am #5761AnonymousGuest
Hi every one! I am doing a flood inundation mapping, i had made a hecras geometry file by using hecgeoras but the problem i am facing is that i couldn’t get the automatic junction nodes created at the reaches junction point, so when i run the steady flow analysis it gives me an error that missing boundary condition on downstream side of profile 1. Needs help on this issue…
March 31, 2015 at 6:57 pm #9231Chris G.KeymasterReturn-Path:
Received: from mail-qg0-f42.google.com (mail-qg0-f42.google.com [209.85.192.42])
by mbob.nabble.com (Postfix) with ESMTP id C42A2ADC9B3
for; Tue, 31 Mar 2015 06:45:09 -0700 (PDT)
Received: by qgfa8 with SMTP id a8so14866358qgf.0
for; Tue, 31 Mar 2015 06:57:50 -0700 (PDT)
d=gmail.com; s=20120113;
bh=Lk1UawuXbkSrWrzKgHCoXRwiZGBvRq/ddFWrvv6lGew=;
b=KmiIxhPEAbGjOoTAyFPIjEgjJkVfa6hbg9ELQaB5SR57MMV6KP5pfyfjEaY/purucV
BBkEn0B+4nM+k2UcRoPi3CR1DafvxicInggoQt6DK9iVoFqetcTxzzpqZz8A2iSuIbn8
POOYOlwzIqjirr96YmVhqnS6nOzzU6rRoHg3f5mjKBZPztwLOvLTDKjL6IBpG6JcBejU
rNndvh5DOI7OrXk9V06EK7KgzhmYZw5Z+MQrMV++0tFNEy7AABwrkrFJI7sZ9Lssa9kR
h4TlFymDZ+b8ZxJJu7pLEAQCaLAlOQ93/8o1N9ENqE5yennHIRapjzoamBY0jxApq/2s
EkBg==
X-Received: by 10.55.56.75 with SMTP id f72mr77956363qka.75.1427810270303;
Received: from ?IPv6:2600:1006:b157:6bbf:14ea:f0e7:47b5:41c5? ([2600:1006:b157:6bbf:14ea:f0e7:47b5:41c5])
by mx.google.com with ESMTPSA id j94sm9946219qgd.47.2015.03.31.06.57.48
for
Tue, 31 Mar 2015 06:57:49 -0700 (PDT)
Subject: Re: Reach Junction
boundary=Apple-Mail-3EB4E184-C46B-4773-8A7D-41546A8D6346
X-Mailer: iPhone Mail (12D508)
Message-Id:
Date: Tue, 31 Mar 2015 09:57:46 -0400
To: “Ali [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-3EB4E184-C46B-4773-8A7D-41546A8D6346
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableMake sure the reach lines snap together in GIS. That way GeoRAS will recogni=
ze the junction. If you don’t want to go back to GIS to do this, you can cre=
ate a junction by moving the reach end points on top of each other. Use the “=
Edit…Move Points/Objects” feature.=20Sent from my iPhone
> On Mar 31, 2015, at 1:00 AM, Ali [via HEC-RAS Help]
wrote:
>=20
> Hi every one! I am doing a flood inundation mapping, i had made a hecras g=
eometry file by using hecgeoras but the problem i am facing is that i couldn=
‘t get the automatic junction nodes created at the reaches junction point, s=
o when i run the steady flow analysis it gives me an error that missing boun=
dary condition on downstream side of profile 1. Needs help on this issue…=20=>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Reach-Junction-tp1490.html
> NAML–Apple-Mail-3EB4E184-C46B-4773-8A7D-41546A8D6346
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitMake sure the reach lines snap together in GIS. That way GeoRAS will recognize the junction. If you don’t want to go back to GIS to do this, you can create a junction by moving the reach end points on top of each other. Use the “Edit…Move Points/Objects” feature.Sent from my iPhone
On Mar 31, 2015, at 1:00 AM, Ali [via HEC-RAS Help] <[email protected]> wrote:Hi every one! I am doing a flood inundation mapping, i had made a hecras geometry file by using hecgeoras but the problem i am facing is that i couldn’t get the automatic junction nodes created at the reaches junction point, so when i run the steady flow analysis it gives me an error that missing boundary condition on downstream side of profile 1. Needs help on this issue…
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Reach-Junction-tp1490.html
NAML
–Apple-Mail-3EB4E184-C46B-4773-8A7D-41546A8D6346– -
