Welcome to the RAS Solution Forums HEC-RAS Help RC curve outlet issue
  • This topic has 3 replies, 577 voices, and was last updated 7 years ago by Anonymous.
  • #7048
    I’am totally in trouble with the RC outlet curve editor in HEC RAS.
    Basically i need to model a bottom spillway of a DAM for which is know the relation H-Q.
    So I just drawn my spillway in the geometry editor and I copied the coordinates in the EditGISDataTable of the outlet centerline table in RC curve editor.
    I also specifed the outlet width and the stationing along the SD/2D connection structure.The H-Q curve was also specified in the outlet rating curve table.
    I noticed that only in RAS mapper is possible to visualize the outlet centerline but not in geometry editor.
    When i try to run the model i get this message:
    SA/2D Connection: Dam
    ” – Outlet RC: has GIS coordinates that do not intersect the structure GIS centerline”
    I have tried everything but nothing seems to work.
    Any suggestion?
    D.
    #11746
    Hi, I have the same problem. How did you solve it? Petr
    #11747
    I have the same problem….
    #11748
    mowens
    Hi did you manage to figure this out?
