Welcome to the RAS Solution Forums HEC-RAS Help Rating Curve from Unsteady Flow Analysis
  • This topic has 2 replies, 855 voices, and was last updated 8 years ago by kevin.
  • #6459
    kevin
    Hi, all, I am doing a unsteady flow analysis for a single reach river channel. With flow BC at the upstream and water stage BC at the downstream.
    At the most upstream cross section, the model produces such a weird-looking rating curve.
    — First, why does the line is wangling like that (instead of being a single curve)?
    — Second, in general, it seems large flow corresponds to small water gauge. How does that happen?
    — Does that indicate some error with the model? (The computation window does n’t give any warning or error).
    Any hints are appreciated!
    Thank you!
    #10575
    kevin
    When I look at the View/Rating Curves…, I get the complete curve. And the previous curve is the upper part of it.
    It varies with the in-flow boundary condition.
    Sorry about the confusion.
    #10576
    how did you solve the problem please
