Welcome to the RAS Solution Forums HEC-RAS Help RasMapper – change units to Meters
  • This topic has 6 replies, 1,762 voices, and was last updated 7 years ago by Anonymous.
  • #6944
    Hi all,
    could you tell me how can I change units in RasMapper from feet to meters?
    I have SI Unit System selected in main HecRas window, but still feet in RasMapper.
    I use also prj file, with defined projection in meters.
    I could not find any “Options”, where I can change the units.
    Martin
    #11475
    As far as I know, the units in RasMapper have to be same as the units in your terrain file. So if the terrain is feet, you are stuck with feet if you want to use RasMapper.
    #11476
    Thanks, but, this is my problem. My terrain has projection in meters, but all units in RasMapper are in feets. When I open Geometry window I have units in meters.
    Martin.
    #11477
    PaoloP
    In RAS 5.0.5 RASMapper Tools –> Options XS River Stations Units by default is feet, but you can easily change.
    #11478
    PaoloP
    #11479
    Hi thanks,
    I know about that option, but still doesnt work for me. I changed to meters, but RasMapper units are stil feets. I guess it is bug, because I have set Dx a Dy of my 2D cell size to 3 feet (also map coordinate in RasMapper is in feet) and when I open it in Geometry window it is set to 3 meters (because I used SI units for hec project).
    #11480
    Hi all,
    Thanks for helping.
    I create new project and everything is working OK now. I dont understant why, but nevermind, it is working 🙂
    Martin.
